18" 350z/G35C Wheel Question
Old Aug 17, 2004 | 09:28 PM
oakes57's Avatar
Both these sets of wheels are all four 18"x8" with 30mm offset, but they are labeled front and rear, which if you have tires on them you can't tell anything but if you have them off and just the wheel, there is an extra ring around the fronts. Why is there this difference and can these be rotated. BTW while the org was down I got 18" 350z Performance wheels (6 spoke) and 235/40/18 pirelli pnero zero m+s tires. I am about to get s-tech's with illuminas or agx (which one should I get) Should I be worried with this setup with the 30mm offset??
I really need to know what is going on with these wheels labeld front and rear cause the deminsions are the same, but there IS a difference. If you bought these with the tires mounted you would never know.
Also I am doing the brakes at the same time are there cheap rotors out there that are cross drilled or sloted?? Which brake pads??
That's alot of questions, but again I went off the deep end while the org was down. Thanks for the help I will post pictures when all complete!!
Old Aug 19, 2004 | 01:55 PM
oakes57's Avatar
Thanks for all the response!! I know there are at least 10 people on here running G35c or Z wheels, what do you plan to do when it is time to rotate??
Old Aug 20, 2004 | 09:50 PM
The Legend's Avatar
If you got these off of a G35 the front rims are not the same size as the rear. Now if they are just two pair of front rims then there should be no problem rotating them. If your still a little weary about putting them on your ride Ill take them off your hands if the price is right.
Old Aug 21, 2004 | 01:47 AM
Nismo's Avatar
30mm will be nice and flush with the fender I have 35mm 18x8 with 235/40/18 and it sits nice
Old Aug 21, 2004 | 04:25 PM
oakes57's Avatar
They are not different sizes the are the same the 17" are staggered, I said in the first post mine are Z wheels although both g35 and Z 18"s are 8" width all around with staggered TIRES(unless Z track edition). And last I am not selling them to you for nothing. Thanks for your usefull post this thread has been very helpful the week I have had it open.
The Frye
Sep 2, 2021 11:03 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
