Another HP EVO question
Old Aug 29, 2004 | 05:19 PM
ACEEMaxima's Avatar
Hey I'm new to this site. I just got a 96 5 spd SE last wednesday, and I'm about to order some rims. Before I came on this site, I wanted to EVO wheels, and after coming on the site I see everyone like those wheels. And I've read a couple threads, and I'm kind of unsure about the wheels now. I wanted to get 18X8. And 1) I wasn't sure what size tired would be better, especially after reading all the threads 225/235/245...2) if I would have probs putting them on...needing spacers and etc... So if anyone can help me out please. I'm so use to running honda stuff...the maxima is new to me. So..any suggestions please inform me.
Old Aug 29, 2004 | 06:42 PM
JC_2k_SE's Avatar
im running the 18x8s on my 5th gen and theyre paired with 245/40/18 Toyo Proxes 4 and i have no complaints. ran into a few minor problems with the install but i dont know if they will apply to your 96
Old Aug 30, 2004 | 08:16 AM
ACEEMaxima's Avatar
What probs did you have?
Old Aug 30, 2004 | 08:48 AM
JC_2k_SE's Avatar
on the rears the dust caps got in the way so i removed them because with the new centercaps they were sealed tight enough to prevent any problems
on the fronts the the axle sticks out a bit too far and does not allow the centercaps to fit on properly (see pic)
theres 2 ways to correct this, some people shave down the metal and some just modify the centercaps (im doing the latter)
Old Aug 30, 2004 | 03:11 PM
ACEEMaxima's Avatar
Will spacers help out with this problem?
Old Aug 30, 2004 | 05:59 PM
JC_2k_SE's Avatar
yes but i dont know what size, im pretty sure i remember someone used spacers successfully with these wheels but i dont know who
Old Aug 30, 2004 | 07:47 PM
BLKMAX005SPD's Avatar
U can get the front cut to make it fit...i just been to lazy to do it...but it should fit after you cut the metal off...
i love my rims...
Old Aug 31, 2004 | 08:09 AM
ACEEMaxima's Avatar
cut what the front axles? Blkmax....what drop you have on your car?
Old Aug 31, 2004 | 08:25 AM
ACEEMaxima's Avatar
what size tire...blkmax I see you have 245, do they rub??? I was thinking about 235.
Old Aug 31, 2004 | 10:08 AM
the tires i have are 235 45 18's with tein springs and it doesn't rub at all..
back to topic...you can cut the front part of the metal...where it sticks out...
you only need to but it a little bit...someone on here has done it i forget who though...
i just don't have anytime to get it done since i work so much...
and being a little lazy when i have my days off hehe
i am going to get it done sooner or later
Old Sep 3, 2004 | 06:26 AM
cardana24's Avatar
Blown
I have a fourth gen and mine fit fine with out cutting anything or using spacers
Old Oct 15, 2005 | 08:24 AM
mwheels's Avatar
i have the same rims and have the same prob as jc 2k se and i heard that shaving up to the cotter pin is alright, and adding a quarter inch spacer (if needed) will correct this problem, i plan on doing this, but does anyone else have any other suggestions on what to do before i actually do it??
Old Oct 15, 2005 | 10:26 PM
ACEEMaxima's Avatar
hey I have shaved my front axles and I have removed my dust caps...and haven't had any problems since...dang Ive had my max for a while now....
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
