Hub diameter
Old Sep 10, 2004 | 01:23 PM
Mack Daddy's Avatar
Hub diameter
I am sure this has been written somewhere but what is the hub diameter? 60 mm or 65 mm or something like that?
My real question is if I buy wheels with a hub diameter of 75mm what needs to be done so that they will fit properly. Is there an adaptor or can you just leave it the way it is and not worry?
Old Sep 10, 2004 | 02:31 PM
nick's Avatar
our hub diameter is : 2.598" or 66.06 mm , You'll need hubcentric rings to compensate for the difference. I'm pretty sure that wheel with bore size of 75 should fit with the proper hubcentric ring.
Nick.
knight_yyz
Nov 6, 2015 02:34 PM
Andy29
Sep 29, 2015 05:32 AM
londonflu
40
Sep 25, 2015 09:11 AM
