Is 235-40-18 not wide enough for 18 x 9 rims?
Old Sep 27, 2004 | 06:03 AM
Dasyce's Avatar
I like the way my 235-40-18 look on my 18 x 8 rims, do I need to go with a wider tire size to maintain that clean square look?
What tire size should I look for?
If any one could send of link me pictures of what tire size they have with 18 x 9” wheels, I would appreciate it.
Thank you!
Old Sep 27, 2004 | 06:35 AM
Mizeree_X's Avatar
Getting back to his roots
Thank you!
And you picked yellow because????
They will fit on a 9" rim, but probly won't maintain that "clean square look".
Old Sep 27, 2004 | 06:51 AM
Dasyce's Avatar
Got sick of the white letters, so I tried blue, (but on the black background its hard to see!!) So yellow it was.
Would I be better of trying 245-40-18?
Pics Please!!
Old Sep 27, 2004 | 08:24 PM
Ammi's Avatar
350 Detroit Muscle
on 9" wide wheels, I would run 255s or 265s
Old Sep 28, 2004 | 05:36 PM
river57c's Avatar
I agree, for a nine inch wide rim, run em wider to fill them in. Unfortunately our Max's do not take such wide tire. I think the max is 235 and some to 245.
Old Sep 28, 2004 | 07:57 PM
Ammi's Avatar
350 Detroit Muscle
There's someone running 265s
Old Sep 28, 2004 | 09:20 PM
steven88's Avatar
Need A Light?
I believe on a 5th gen...the widest you can go up front is 265 and the correct offset....anything more than 265 requires a lower offset without rubbing...but then it would stick out the fender and look rediculous......and i think the rears a 275-285 tire is the widest you can go with the correct offset.....without sticking out of the fender that is...
iirc......slammed95 tested these results with his 17x9 265's rim/tire on a 5th gen and got these results....correct me if i am wrong
Old Sep 29, 2004 | 03:47 AM
Norm Peterson's Avatar
235/40-18 is approved for rim widths from 8" to 9.5".
Norm
Old Oct 14, 2004 | 09:10 AM
maseo77's Avatar
Norm
I wouldnt reccomend a 235 tire on a 9.5 rim, that is a very wide wheel
Old Oct 15, 2004 | 08:10 AM
Triple8Sol's Avatar
I miss the .org!
Go with 255 or 265. PERIOD.
Old Oct 15, 2004 | 10:12 AM
CamryKilla's Avatar
245s will be fine and square, but 255s would look fat and badass
Old Oct 17, 2004 | 08:26 AM
Triple8Sol's Avatar
I miss the .org!
Originally Posted by slammed95
245/40 will be fine. I'm guessing you're gonna have the same size all around.
You really think that would work? I mean 245 or 235 is good on an 8" wide, but on a 9"
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
