"FIX" for HP EVO's
Old Oct 12, 2004 | 11:13 AM
maseo77's Avatar
"FIX" for HP EVO's
From what I've read in previous posts about HP evo's the center cap for the front wheels do not fit correctly on our cars and there is a way to make them work. Anyone know about this?
Old Oct 12, 2004 | 04:28 PM
JC_2k_SE's Avatar
i had this problem when i installed mine. all i did was get some black plastic stock about 1/8 thick, cut 2 circles with a 2 inch diameter, then put a 1 inch hole in the middle. superglued the two of them together (you need about 1/4 of plastic to fit over the peice that sticks out), then onto the black centercap they give you and finally put the logo on top.
by the way, i wish i had evos on a 2000 grey lustre, its got to be the sexiest look out there by far!!
you can sortof see the extensions on the centercap but you cant really tell unless your looking for it
Old Oct 12, 2004 | 10:26 PM
apbrian112's Avatar
5mm spacer...
Old Oct 13, 2004 | 07:34 AM
maseo77's Avatar
Originally Posted by apbrian112
5mm spacer...
how would spacers look with a 38mm offset?
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
MaxTuner
Jan 18, 2002 06:48 AM
NJ_MAX2000
20
Nov 3, 2001 03:21 PM
