Does a smaller diameter tire affect brake/ABS performance?
Old Oct 29, 2004 | 03:43 PM
beeda's Avatar
I just put 225/45 R17 Toyo Proxes 4 on my 2001 SE 17” oem rims. I knew that since the size was different, I would be going slower than the speedometer reading and running less miles than the odometer reading. Since the tire specifications allowed for 7” rims however, I wasn’t worried about any safety compromises.
Recently however, I came upon 1010tires.com and found their tire size comparison calculator. I punched in my old tire numbers and my new tire numbers, and was told that the difference in the diameters was greater than 3%, and that I might experience brake failure. (Just for the record, my own measurements of the actual differences in the tire sizes gave me only a 1.7% difference, so I am not as worried).
Does anyone have any info on whether or not a smaller tire size will affect brake performance, and specifically the ABS? I bought these tires because they were magnitudes better than the oem Potenzas—but I don’t want to create safety issues just by using a smaller size.
Old Oct 29, 2004 | 04:02 PM
JeffesonM's Avatar
living out of a maxima...
I wouldn't worry about it... my rims/tires are like 2% over stock and I have a big brake kit, and ABS still works fine.
Old Oct 30, 2004 | 06:26 PM
Triple8Sol's Avatar
I miss the .org!
Since you went with a better tire than your old stockers, it should improve your braking. Good question as far as ABS...I'm not sure how diameters affect that...anyone?
Old Oct 31, 2004 | 01:52 PM
beeda's Avatar
Thanks guys! I suppose that if ABS engagement is based on wheel speed, then with smaller tires it should only turn on a fraction sooner if anything (since it thinks my tires are going faster than they actually are).
Any idea then why they say that a 3% diameter difference over stock might lead to brake failure?
spencerwh1
Jun 30, 2016 05:44 AM
240tomax
Tires and Wheels
Feb 10, 2016 11:01 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
Serotta33
Sep 17, 2015 12:14 PM
