larger tire on 16" rims?
Old Nov 3, 2004 | 07:45 AM
dennisuello's Avatar
i have stock 16" wheels on my GLE with 215/55R16 tires. has anyone run 225/55 or 235/55 tire on those rims?
Old Nov 3, 2004 | 07:53 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
You might wanna try 225-50-16s, they will fit. Speedo won't be off eighter. 235 will not fit that rim, it will bulge out the sidewall.
Old Nov 3, 2004 | 08:08 AM
i am leaning towards 225/55R16 Continental ContiExtremeContact
http://www.tirerack.com/tires/tires....omCompare1=yes
looks good for a $73 tire
Old Nov 3, 2004 | 09:22 AM
rule da road's Avatar
I run 235-55 on my 17 so i guess it should fit a 16 also. It does bulge out a bit but looks real agressive. It fills the wheel well like the car is dropped. The contiextreme is a good tire from what i see but i got the kumho extas and the perform wonderfully.
Old Nov 4, 2004 | 09:49 PM
jdm71488's Avatar
Originally Posted by TopElement
I wouldn't recommend going more than 1 size wider on stock wheels. OEM fitments are already too rounded and don't keep the tire tight on the wheel, going wider just makes things worse.
so stick with 225/50/16?
Old Nov 4, 2004 | 10:00 PM
jdm71488's Avatar
That is correct. If you want wider tires, get wider wheels.
i like my stockers... im gonna order some contiextremecontacts in that size for em too!
rated 3rd on tirerack... i believe
Old Nov 5, 2004 | 11:05 PM
any opinion on these?
Bridgestone Potenza G009
Old Nov 6, 2004 | 12:42 AM
tedo007's Avatar
faster than you think
thas what im trying to get too
Old Nov 8, 2004 | 01:12 PM
BRAN808's Avatar
Tires
I got 225/50/16 on my '00 SE, and the tires look just right. I think any wider, and they'll look too fat and bulge out. Also the 235 may fit for the 17's but it depends on the width of the rim for the 16's.
Old Nov 8, 2004 | 03:40 PM
rbeyer's Avatar
I was in the same situation when replacing my tires for my stock 16's about two weeks ago. Went with the factory size.
Toyo Proxis 4's going on tomorrow perhaps!
www.edgeracing.com great deal!
Old Nov 18, 2004 | 07:22 AM
Chris99SE's Avatar
Does anyone have any experience running the 225/55/16 tire? I know that it will change the speedo a little but for $73 per tire, it can't be beat. Is there a handling difference with the 50 series to the 55 series? Thanks
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Garrettz459
Sep 28, 2015 02:50 PM
