Vibration after new tires installed!!!!
Hey there!!
Well, I purchcase a full set of Federal SS 595 tires for my Max a few months ago. they're the stock 225/50VR17 size. and for a fair price. Well, after a four wheel balance and a four wheel alignment, I took it on the freeway and I was shaking all the way to work..... I went back and thought that the fronts were out of balanced. The shop rebalanced the fronts and went on my way, after work, I was now shaking in the back...went one more time and got the rears rebalanced. After that, I was ok. No more shaking. After about 5K miles, I went to get the tires rotated ( front to rear, rear to front ) and when I went to work....all four tires were out of balanced again!!! What could be wrong!! I saw the shop guy rotate the tires for me. Nothing out of the ordinary. None of the tires were modified in any way, all the weights are still there. Could my suspension be worn already or the alignment just be off again or something.
What should I do. The alignment was only a 30 day warranty. and that's way off already. Any comments would be appreciated. I have 39,305 miles on the car and slighty over 5k on the tires.
Thanks.
BTW: the tires offer excelent ride and traction!! Not to mention a sweet looking tread.
Thanks.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Originally Posted by z32drifter
I suspect that the tires are the problem..... you may have a roadforce problem... or the tires may be flatspotting when sitting for awhile.... is the vibration the same at the same speed all the time??
After the roation, that same lane I travel, I'm shaking all over. I changed lanes to and from work to see if it was the asphalt but it still shakes.
I'm thinking that it might be the tires. i'm going tomorrow Wed to have them checked. I still have the Warranty on them so might as well.
Originally Posted by Bman
If you suspect the tires and have tried everything else, take it to a shop with a Hunter GSP9700 and get them to check everything out (road force match balance I believe).
Would you know any major tire chain companies that would have that machine, like Discount Tire Centers or Just Tires stores..? Any info would be great, thanks. Any in the Los Angeles, California area as well too. Thanks again.
Starrider
09-17-2015 07:26 AM
02nissmax
09-05-2015 01:50 PM
dutch078
Wheels/Tires
08-03-2015 06:58 PM
