225/55/17
Old Nov 15, 2004 | 12:28 PM
MaxMaMaSE's Avatar
225/55/17
Can these be used on stock rim? I found a good deal on some Pilot Sport A/S in this size??
Old Nov 15, 2004 | 02:16 PM
Manaz101's Avatar
yes, i had 235/55 17's on my back wheels, on the stock SE wheels. Worked fine, i actually liked the way they looked over the 225/50.
Old Nov 16, 2004 | 04:13 AM
MaxMaMaSE's Avatar
You ran 235/55... I would like to know about 225/55... I don't think it should be much of a difference just a slightly higher sidewall. Obviously I am not looking for Extreme sport action in this Max - it is my better halfs daily driver. Potenza's are getting dangerous.
Old Nov 17, 2004 | 04:03 AM
MaxMaMaSE's Avatar
So? Is anyone running 225/55/17????
Old Nov 17, 2004 | 04:15 AM
SEmy2K2go's Avatar
Go BUCKS!!!
225/55/17 will add quite a bit of sidewall. Can you not get the same deal on the correct size?
Old Nov 17, 2004 | 06:55 AM
MaxMaMaSE's Avatar
No, I can't. That is why I am asking. Doesn't seem like many are running this tire.
Old Nov 17, 2004 | 07:09 AM
Manaz101's Avatar
I don't think anyone is running those because it doesn't really add much of a difference. Like stated before, it's just a little bit more of a sidewall. If you can get them for cheaper i'd do them. They look a little better in the back IMO, they fill in the gap a bit more. or maybe it's just me.
Old Nov 17, 2004 | 01:56 PM
SEmy2K2go's Avatar
Go BUCKS!!!
At 60 mph, you'll actually be doing about 62-63...just fyi.
Old Nov 17, 2004 | 06:12 PM
BigFly_2K2SE's Avatar
I think I remember one member a while back (JJS ?) saying that he was running on 225/55-17 tires and he was quite happy with them. I believe they will work fine.
Old Nov 17, 2004 | 06:39 PM
.45's Avatar
.45
I seriously considered (researched) them but went with 225/50's in the end on stock GLE rims. I've read a few related threads here and all were generally positive. The only thing I recall was a comment that noted "the space between the tread surface and the rear factory splash guards if you have them might be tight." I believe that was 225/55's on stock GLE rims as well (slightly different offset than your SE rims).
maxim82
Mar 29, 2011 01:09 PM
Calcvictim
Tires and Wheels
Apr 22, 2010 08:27 PM
Ammi
Wheels/Tires
21
Dec 8, 2007 10:15 PM
