235/40-18...What tire pressure you running?
Old Nov 27, 2004 | 06:55 PM
Link112's Avatar
Not sure on tire pressure when going up in wheel size (17x7 to 18x8). I have been told that the tires need to be inflated to 38-40 lbs. and that these should run a little less than my stock 17's did at 33 lbs. 38-40 lbs. feels like I am riding on stones, but I don't want to go too low in tire pressure and take a risk of bending a rim, not to mention wanting to get the most mileage out of the tires.
What tire pressure do you run with 235/40-18?
Thanks!
Old Nov 28, 2004 | 10:43 AM
TsingTsaoNYC's Avatar
36 psi in front
34 psi in back
Old Nov 28, 2004 | 09:39 PM
Link112's Avatar
Thanks! I will give it a try. I think I am at 36 all around right now.
Old Nov 29, 2004 | 11:37 AM
Max20SE00's Avatar
does tire pressure matter with what rim size you are running. Like between a 18x7.5 inch rim compared to a 18x9? I have a set of 18x7.5 42 offset and getting 235/40/18 is the 36 front 34 back a good combination for that? Thanks
Old Dec 1, 2004 | 09:09 PM
Max20SE00's Avatar
Are we talking cold psi or hot psi with those numbers?
Old Dec 2, 2004 | 06:54 AM
Link112's Avatar
I think we are talking cold. 35lbs front 33lbs. back seems to feel pretty good. That is the reading when tires are cold. I don't carry many people or weight in my car.
Maxboy23
Sep 8, 2015 06:53 PM
02nissmax
Sep 5, 2015 01:50 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
