Safe to use this tire size on 16" rims?
Old Dec 9, 2004 | 04:04 AM
elcid's Avatar
I have a 98 Maxima SE with the 16" alloy stock rims. I am wondering if it is safe to use the following tire sizes, and which is the best size:
205/60/16
195/60/16
reason being is I have to chnage my tires, and I can get a good deal on both those sizes, I would save about $200. BUt will it screw anything up? Like ABS or soemthing? It's an automatic, fully loaded. Thanks in advance!!
Oh and the stock tire size is:
215/55/16
Old Dec 9, 2004 | 04:17 AM
DemonSpawn's Avatar
No .. don't do it. Get at least the stock size, I cannot stress enough how much getting a smaller tire is bad for handling and safety.
Check tirerack.com for good deals on the correct size tire for your car.
Old Dec 9, 2004 | 07:41 AM
datguyclark's Avatar
206-60-16 is totally fine...will not be unsafe in the slightest, i have been mounting tires for years and never seen or even heard of 205-60-16's being unsafe on a max
Old Dec 9, 2004 | 09:43 AM
Bman's Avatar
You'll probably be okay with 205/60. Load rating is even similar or only slightly lower, which is usually fine. Size difference is 1.5% which isn't significant. Just don't drive at 99.9% of the car's limit like you used to with the old tires.
Old Dec 10, 2004 | 03:25 AM
elcid's Avatar
Excellent...Thanks!!
Old Dec 10, 2004 | 08:47 AM
Brudaddy's Avatar
Why would you want to go skinnier with the tires rather than wider?
That would not be the best route, IMO.
I understand a good deal, but think about what you are doing?
spazma7ik
Jan 12, 2017 09:38 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
Serotta33
Sep 17, 2015 12:14 PM
