42mm Offset
Old Dec 23, 2004 | 08:17 PM
ucdaznboy96's Avatar
42mm Offset
Saw some rims I like:
http://www.enkei.com/HPSpecPAGES/rpo3Specs.html
However it has a 42mm offset...is that problematic? What tire size would be recommended to go along with these?
Old Dec 23, 2004 | 09:13 PM
Ammi's Avatar
350 Detroit Muscle
If you are thinking of getting some 18s, get 18x8.5 w/ 35mm offset. For tires, use 245/40/18s.
Old Dec 23, 2004 | 10:45 PM
newbie question...but what is the offset on our stock 03 SE rims?
Old Dec 23, 2004 | 11:00 PM
steven88's Avatar
Need A Light?
17x7 45mm offset with 225/50/17 is our stock tire
Old Dec 24, 2004 | 07:53 AM
myktek's Avatar
just in case if u didn't get my pm... here are the dimensions on my wheels
Racing Hart Type C5 3 Piece
18x8.5 45 offset 245/40/18 1" lip
18x9.5 44 offset 275/40/18 2" lip
http://home.houston.rr.com/myktek/rims/
http://home.houston.rr.com/myktek/rims2/
Old Dec 26, 2004 | 12:43 AM
Audtatious's Avatar
Bandwagon Lover
18x7.5 will work fine as well. Same as stock '04+ Maxi. With 245, a 35mm offset would look better and fill the rear wells out. With 235's, a 30mm offset would probably work.
Old Dec 26, 2004 | 08:44 AM
Ammi's Avatar
350 Detroit Muscle
You want to take wheel width and offset into consideration; not tire width and offset.
I definitely recommend going w/ at least 8" wide rims.
Old Dec 26, 2004 | 10:20 AM
Audtatious's Avatar
Bandwagon Lover
My post was concerning 7.5" wheels which are easier to find. Circumference on a 245 is 1" greater than a 235. If you are running a 30mm offset, this may cause some rubbing of the outside wheel well "inner lining". Better safe than sorry?
Old Dec 26, 2004 | 11:04 AM
So it looks like 19 x 8.5 with a 42mm offset will work depending on the tire? Will it stick out too much?
Old Dec 26, 2004 | 12:02 PM
NYPD-Arnold's Avatar
Z
Our stock rim is 38mm, not 45.
Old Dec 26, 2004 | 01:36 PM
Ammi's Avatar
350 Detroit Muscle
Wrong. It's 45mm.
Old Dec 26, 2004 | 01:37 PM
Z
Originally Posted by Ammi
Wrong. It's 45mm.
Irish made a thread about it and everyone said it was 38. Or was it the other way around? :|
Old Dec 26, 2004 | 01:44 PM
Ammi's Avatar
350 Detroit Muscle
5th gen has 17x7 w/ 45mm offset and 6th gen has 17x7.5 w/ 40mm offset.
Old Dec 26, 2004 | 01:46 PM
WildmanAL's Avatar
I was looking into getting those wheels in 19's, but I wanted a lower offset.
Old Dec 27, 2004 | 04:16 PM
so a higher offset (42mm) means that the wheel will stick out too much correct?
Old Dec 27, 2004 | 04:36 PM
steaLthyMax's Avatar
you generally want a lower offset on a wider rim so it will look flush, the reason why the stock rims' offset is so high is because it is only a 7 inch wide rim.
Old Dec 27, 2004 | 04:51 PM
WildmanAL's Avatar
The lower the offset the farther the wheels will stick out. 35mm rims will stick out further than a 45mm offset rim.
Old Dec 27, 2004 | 05:15 PM
mclee45's Avatar
i got 18X8 with +38 and i think they're perfect.
Old Dec 27, 2004 | 07:20 PM
Audtatious's Avatar
Bandwagon Lover
http://www.tirerack.com/wheels/tech/offset.htm
Old Dec 27, 2004 | 07:48 PM
Audtatious's Avatar
Bandwagon Lover
The only problem with the lower offsets for all wheels is that the front wheels will stick out further. I have 18x7.5" rims with 40mm offset. Adding a 10mm spacer to the back will change it to a 30mm offset which will make it look better and more equal to the fronts.
Old Dec 27, 2004 | 11:16 PM
Ammi's Avatar
350 Detroit Muscle
Ummmm NO. Wider wheels you get, you need higher offset.
Old Dec 27, 2004 | 11:30 PM
steven88's Avatar
Need A Light?
i thought the SE came with 18x7.5 with 40mm...and the SL came with 17x7 and i dunno bout the offset....maybe 45mm?
correct me if i am wrong
Old Dec 28, 2004 | 03:09 AM
Originally Posted by TopElement
That makes no sense at all. Stock 7" wide wheels have a 45mm offset. So going to 8" wheels with the same offset will already make them stick out 1/2" more than the stockers, and using a 35mm offset will make them stickout over 1" more than the stockers.
For 5th gens, 8.5" wide with 35-40mm offset will be perfect all around.
Yes, 8" wheels with a 35mm offset would make them stick out more than the stockers, but if you want the rims to look flush instead of sunken like the stock rims, wouldn't that suffice?
Not necessarily. If you got wider wheels, and a higher offset, the wheels would stick out more than if you had a smaller offset. 18x8.5+35mm would be closer to being flush than 18x8.5+45mm, which would be sticking out a lot.
Old Dec 28, 2004 | 08:58 AM
Audtatious's Avatar
Bandwagon Lover
See the "quickie" image below:
The first diagram shows a 45mm offset. That means, the center section of the rim is +45mm from the true center of the rim. This makes the rim "sit in" further from the lip of the fender. The second diagram shows a 35mm offset. Since the offset is -10mm from the 45mm offset rim, the wheel will "stick out" more and be closer to the lip of the fender in comparison to the 45mm variation.
Make sense?
Old Dec 28, 2004 | 09:58 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
http://www.enkei.com/HPSpecPAGES/rpf1Specs.html
What do you guys think of these wheels ? I need some LIGHT wheels and I'm conteplating on whether get Enkei RPF1s 18x8.5 with 30mm offset, I have big calipers to clear on my Maxima and anything smaller than 35mm will rub.
Or these
http://www.enduromotorsports.com/RaysGTP.html in a similar size ?
I want something light, wide, and no cheap **** like ADR, Velox, etc.
Old Dec 28, 2004 | 10:40 AM
TET- I went to your site, the pictures are not working for all the 5th gen parts, I wanted to see more pictures of the RPF1s on your car. I currently have 17x8 38mm offset Enkei RPO1s and they barely clear my TTZ calipers on 04 Maxima rotors. I am going to get a set of new wheels in the spring, any places you would recomend to buy from ? inexpessive ? I'm looking at Advan RGs, TE37s, SSR Comps, GT-Ps, few Work wheels, and Nismo wheels for 350Z. I was almost set on the Nismos, but decided to take a look at other wheels in the 2K dollar price range.
Old Dec 28, 2004 | 01:23 PM
No, the 35 will stick out more.
yeah i agree...but the 35 would look more flush than the 45..i guess thtas what i was trying to say...it was late last night...
Old Dec 29, 2004 | 12:47 PM
Make sense?
This is excellent information. THANKS EVERYONE. So that means, 19 x 8.5 with a 42mm offset (which concerns the trims I want in the beginning of this thread) will most likely cause rubbing issues with the inside, and it won't even look flush with the fender. Am I correct?
Old Jan 5, 2005 | 08:28 PM
So does anyone actually have a 42mm offset rim? I'm trying them on this weekend, so I'll let you know whether it rubs and how it looks...
Old Jan 5, 2005 | 10:07 PM
Ammi's Avatar
350 Detroit Muscle
They won't rub. I had 18x8.5 SSRs 42mm offset w/ S-Tech drop.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
