Curb Rash on my 19's!!!! Need Help
Old Jan 7, 2005 | 11:35 AM
PearlWhtMaX2000's Avatar
today i was parking my car outside of work, and rubbed the side of the rim against the curb a lil bit. its about 2 inches, on the outer lip of the rim. anything i can do?? sand it down? or is there a place that would fix it?
ill take pix if needed and post them.
Alex
Old Jan 7, 2005 | 12:14 PM
BRAN808's Avatar
I know that down here, we have a guy named Todd. His companies' name is Alloy Wheel Repair Specialists. They do repairs on Alloy wheels, but it depends on the severity of the damage, and the finish of the wheel. We use him a lot for insurance claim work with OEM wheels, but he also does aftermarket. He typically charges about $100. He quoted me $50 for a small 1" gouge on my G35's. ( Personal price! ) and that was for a "spot repair." For the repair and full refinish of the wheel, it would have been $150. Not bad, as compared to buying a new wheel. Your wheel looks like a Hyper black finish, just like my G's, so I'm pretty sure there must be somebody up there that can do it for you. Good luck!
Old Jan 7, 2005 | 12:45 PM
Triple8Sol's Avatar
I miss the .org!
Call or go to your local Discount Tire, etc... and ask them where they send rims for repair.
Old Jan 7, 2005 | 01:27 PM
Mizeree_X's Avatar
Getting back to his roots
http://www.bmwtips.com/tipsntricks/w...uff-repair.htm
Old Jan 7, 2005 | 05:34 PM
the thingis that the part with the scuff is chrome.
Im ganna try what Triple8Sol said,and try a wheel shop
Old Jan 7, 2005 | 11:25 PM
whazzzzuup's Avatar
I suggest sanding them it down and polishing it again with Mother's wheel polish. My friend bought these 3 piece Racing Hart C5s for 75 bucks. All the wheels were in terrible condition, just like the one in the picture. I used 150 grit, then 400 grit, then 2000 grit. After that, I just polished it with the Mother's polish. It took about 2 hours to do all 4 wheels.
Old Jan 7, 2005 | 11:36 PM
whazzzzuup's Avatar
Here is a scratch on my SSR's that I fixed with the same method:
Old Jan 8, 2005 | 10:36 AM
wow thats great, so i just polish it down? is there anyhting too look out for, or be carefull with, i havnt done this before.
Thanx
Old Jan 8, 2005 | 11:08 AM
maseo77's Avatar
WoW thats a great job!!
Old Jan 9, 2005 | 12:46 AM
whazzzzuup's Avatar
Thanx
Yes, sir. Just sand it down and polish. It should look good as new.
Old Jan 9, 2005 | 09:22 AM
Great thanx alot.
so i start out with 150 than 400, than 2000 grit. but how long do i sand it down with each one for?
Old Jan 9, 2005 | 12:23 PM
whazzzzuup's Avatar
Great thanx alot.
With the 150, you will go all the way down until all the marks/scratches are gone. This is the most important grit to remove the scratches because its the roughest. The wheel will be still rough, but the scratches will be gone. Then you will need to apply water to either the sanding area, or the sandpaper or both for the 400 and 2000. Apply water, sand it until smooth and wipe off. Repeat if needed. Then just apply the polish a couple times and it will be good and shiny again.
Old Jan 9, 2005 | 01:23 PM
ok thanx alot, ill try to do this soon, and post how it turns out
Old Apr 13, 2005 | 01:38 PM
ok i did it, Came out perfectly!!! thanx alot guys The Org comes through again, i couldnt have done it with out your inputs.
Old Apr 13, 2005 | 04:31 PM
whazzzzuup's Avatar
Do you have any before/after pictures?
Old Apr 13, 2005 | 05:29 PM
Triple8Sol's Avatar
I miss the .org!
So you did it yourself? Good work! Let's see some before/after pics...
Old Apr 13, 2005 | 06:14 PM
i forgot to take before pics but ill post after pics when i go home this weekend.
took me about 20 min, and i added 4 coats of polish.
Old Apr 13, 2005 | 10:12 PM
Ammi's Avatar
350 Detroit Muscle
excellent job whazzzzuup
Old Apr 13, 2005 | 10:50 PM
xtantmaxima's Avatar
The part you fixed is not chrome, just polished which helped you out HUGE this time. If it was chrome, repolishing the area would not have looked good. Nice wheels by the way
Old Apr 13, 2005 | 11:17 PM
whazzzzuup's Avatar
For your viewing pleasure, here is a set I did 2 weeks ago:
Before:
After:
Old Apr 14, 2005 | 09:57 AM
Looks good as new
Old Apr 14, 2005 | 10:59 AM
Battle Max's Avatar
Nice tire selection...
Old Apr 14, 2005 | 12:54 PM
erty67's Avatar
Decal Specialist
I know I'm late on this post, but Don't do it again!
Old Apr 14, 2005 | 01:10 PM
Triple8Sol's Avatar
I miss the .org!
Good work whazzzzuup! Did you dismount the tires when you fixed the damage?
Old Apr 14, 2005 | 01:28 PM
whazzzzuup's Avatar
No, I didn't dismount any of the tires. The Racing Hart C5's didn't have tires on them in the first place. I actually left my SSR wheel/tire on the car when I fixed the scratch. I was lazy to take it off.
Old Apr 14, 2005 | 05:20 PM
ohhhh ive learned my lesson
Old Apr 18, 2005 | 06:54 AM
euromaxima's Avatar
are you guys hand polishing or using a dremel tool or something?
Old Apr 21, 2005 | 12:36 AM
trixy's Avatar
hi there... were these wheels clear coated before you fixed them? if so, how did you remove all the clear coat, and did you re clear coat them when you were done? i have a set of wheels are in about the same shape, but they are gunmetal with a polished lip.
Old Apr 21, 2005 | 12:49 AM
whazzzzuup's Avatar
Yes, they had clearcoat on them, which was chipping off. I removed it by sanding it off, along with the scratches. I did not reclear them (honestly, I don't think you need to).
Old Apr 21, 2005 | 01:59 AM
trixy's Avatar
cool, thanks!
Old Apr 21, 2005 | 05:30 AM
Epacy's Avatar
Unsuccesful STL Coordinator
Nice van. Very resourceful!
Old Apr 21, 2005 | 03:17 PM
mark350z's Avatar
Were can I buy 1500-2000 grit sandpaper
I went to Home Depot and the highest grit they had was 600.
Any ideas?
Mark
2003 350z
2001 Pathfinder
1996 I30
Old Apr 21, 2005 | 04:38 PM
erty67's Avatar
Decal Specialist
Any ideas?
Mark
2003 350z
2001 Pathfinder
1996 I30
Automotive section at Wal-Mart
Old Apr 21, 2005 | 06:28 PM
mark350z's Avatar
Thank you!!!
Hopefully the 1500 grit will do the trick!
Mark
Old Apr 22, 2005 | 12:28 PM
mrgreek's Avatar
i got stock rims 96 gle, can i just do it while its on the car...or will sand a big agitate the tire?
Old Apr 22, 2005 | 12:48 PM
whazzzzuup's Avatar
I did my SSR wheels when they were still on the car. Just try to avoid the tire and you should be fine. If you touch the sandpaper on the electric sander to the tire accidently, just make sure that you don't hold it there for too long. It shouldn't be any problem.
Old Apr 22, 2005 | 01:06 PM
mrgreek's Avatar
can i sand it by hand or do i need electric sander?
Old Apr 22, 2005 | 01:22 PM
whazzzzuup's Avatar
You can definitely sand by hand, which is safer for the tire but is much slower to yield the same results.
Old Apr 22, 2005 | 01:39 PM
mrgreek's Avatar
ok im gonna do it...
now one more question...thats the curb rash...on the rim(lots of solid metalthe stock ones) theres this scratch or something that seems like it peeled off something from the rim...any idea wat the hell that is? does our rims have something like that...or is that the clear coat?
Old Apr 22, 2005 | 02:40 PM
whazzzzuup's Avatar
It sounds like the clearcoat is coming off.
