Please post pics of an 18" rim, with a 40,45, and 50 series tire please!!!
Old Jan 24, 2005 | 07:46 PM
Stuntin' 101's Avatar
just wanna see how the different sizes look.. id like to get a taller tire, but dont want to go too big.. so if any can please post some pics so i can compare it would be much appreciated..
Old Jan 24, 2005 | 10:56 PM
BRAN808's Avatar
Rim Pics
The first picture (left) is with my 18x8 G35's, 245/45/18. The second picture (right) is after I switched to a 2353/40/18. The gap got a little bigger, but took care of my rubbing issues. Same thing goes for below. But the picture is not very clear.
Old Jan 24, 2005 | 10:57 PM
BRAN808's Avatar
Oh, and by the way, 50 series tires would be WAY too big. Please, I beg of you, don't do it!
Old Jan 24, 2005 | 11:05 PM
Triple8Sol's Avatar
I miss the .org!
Depends on the width, but normally I would say 40.
Old Jan 26, 2005 | 10:51 AM
BLUEMAX01SE's Avatar
40 series is gonna be the best fitment for height on an 18 inch wheel. especially if you plan on lowering your car or if you have done so already! 45/50 series would give you rubbing especially when turning! best possible meaty/beefy tire size for an 18 inch wheel for 4th/5th gen is going to be a 245/40 18! good luck
Old Jan 31, 2005 | 03:21 PM
Pit5Bull's Avatar
215/40/ZR-18 Dunlop Sport M901's wrapping a set of 18x8 MKW M12s with 40mm offset. I really wish I knew how heavy these wheels are, but the MKW website doesn't list the wheel weights. (Note that this picture was taken less than 24 hours after mounting, so the front springs have settled down MUCH nicer since then.)
Old Jan 31, 2005 | 03:38 PM
i know that 245/40/18 fit on my car fine.. the 245/45/18 are only 1 inch taller in overall diameter.. so really is only a 1/2 inch on either side of the wheel well
Maxboy23
Sep 8, 2015 06:53 PM
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
twotonezed
Aug 16, 2015 11:41 AM
