Question about spacers
Old Jan 26, 2005 | 11:27 AM
Tuna's Avatar
i just recently acquired some 18" 2k4 SE wheels with tire sizes 245/45/18 all around and i own a 97.. i wanted to stick the rear wheels out a little and am not sure which spacers to buy or if any will fit with these wheels on my car.. i found two on ebay one 15 mm and another thats 20 mm.. also one last thing, if i do go with the spacers would i have to cut off a portion of the stock studs or is it just a plug and play item??
and yes i know that the staggered look on a fwd car is .. tia
-TUNA
Old Jan 26, 2005 | 10:28 PM
xtantmaxima's Avatar
-TUNA
Don't you mean buy longer studs? The spacer fits between the hub and the wheel effectively making the hub several mm farther away then it used to be, thus shortening the number of threads by that same amount of mm. You will need to buy longer studs so you have enough threads to tighten the wheel.
Old Jan 27, 2005 | 05:58 AM
Mizeree_X's Avatar
Getting back to his roots
Did you even check the links he had in his post?
Unclejunebug
Apr 2, 2016 05:42 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Socalstillen
Sep 26, 2015 12:01 PM
