18x8, 30MM offset and 235/45/18- Will this rub on a 5th gen?
Old Jan 27, 2005 | 08:12 PM
Kevin's Avatar
I'm at stock suspension right now but will be lowering this summer. thinking about an set of 18x8, 30mm offset 235/45/18 rims/tires. what do you think?
Old Jan 28, 2005 | 03:03 PM
Kevin's Avatar
hi...10chararcter
Old Jan 29, 2005 | 03:08 PM
Kevin's Avatar
1234567890
Old Jan 29, 2005 | 05:34 PM
maxspeed96CT's Avatar
The original VQ...
um i guess no one knows lol, 30 offset might stick out a tad to much, that is more of a RWD car offset
Old Jan 29, 2005 | 07:42 PM
max5spd's Avatar
Says.."No mo Maximas for me!"
I had 30mm offset from Q45t wheels on my I30t. Yeah, they rub.
Old Jan 29, 2005 | 08:27 PM
Ammi's Avatar
350 Detroit Muscle
they should fit because I could run 18x8.5 w/ 35mm offset
Old Jan 30, 2005 | 10:47 PM
BRAN808's Avatar
You should be ok, depending on how low you're going. I got G35C's and they're 18x8, +30 offset, but I have 235/40/18's. No rubbing issues, and I'm on S-Techs. If you're going with H&R's or Eibach, or Maxspeed's. I'm pretty sure you'll be ok.
Old Jan 31, 2005 | 07:35 AM
Kevin's Avatar
probalby H&R's if anything. thanks
Old Feb 1, 2005 | 03:01 PM
dragonboyokada's Avatar
Will these wheels fit on a 4th gen with Maxspeed springs without rubbing? According to the offset calculator, it'll stick out a whopping 30mm more.
MAXSE5SPD
Sep 17, 2022 04:00 AM
thenewguyy
Sep 12, 2015 11:12 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
