Tire Size Recommendation
Old Feb 10, 2005 | 01:34 PM
fluidculture's Avatar
I just purchased a set of 2005 18" Maxima wheels for my 2002 Max SE. What tire size do I need so there is no rubbing? I'm looking for a nice look and not too big of a sidewall that it makes the 18" look small.
Old Feb 10, 2005 | 06:06 PM
upstatemax's Avatar
try the tire size calculator.... i think a 235/40/18 might work. however you might be able to get closer.
Old Feb 11, 2005 | 08:45 AM
BLUEMAX01SE's Avatar
either do a 235/40 18 or 245/40 18 - i have 245/40's on my 18's and no rubbing whatsoever- i'm even dropped on s.techs too! rim does not look small at all in a 245/40 18 - you're gonna want some sidewall for protection for those puppies! good luck bro
Old Feb 11, 2005 | 02:25 PM
Maximum Depth's Avatar
Here is a nice tire size calculator, which shows how changes to the Width/Aspect/Rim affect the overall size of the tire/wheel. Even shows the changes in pictorial format, and calculates how much your speedometer is affected by changing tire size.
http://www.miata.net/garage/tirecalc.html
RIPTIDER
Wheels/Tires
Jan 31, 2016 07:39 AM
mikeymouse1995
Sep 18, 2015 06:42 AM
Serotta33
Sep 17, 2015 12:14 PM
Johnny9595
Sep 16, 2015 07:20 PM
sdotcarter
Sep 2, 2015 09:53 PM
