Where to get a cheap alignment?
Old Mar 1, 2005 | 10:41 AM
SkoorbMax's Avatar
My alignment is perfect (recently done), but I need to change out the cv boots, and I'll be damned if I'm paying $70 for it to get done again after! Is there a national chain that has cheap alignment? $70 was a quote from big10 tires. I think sears charges $60...
Old Mar 1, 2005 | 11:15 AM
maxspeed96CT's Avatar
The original VQ...
If you were in CT you could get it for 30$
pull up to the back of a town fair tire and talk to the aliment tech, im sure they do side work just like over here.
Old Mar 1, 2005 | 11:32 AM
Triple8Sol's Avatar
I miss the .org!
Or you could buy the Firestone lifetime alignment, and save alot in the long run...
Old Mar 1, 2005 | 12:04 PM
SkoorbMax's Avatar
Right, but isn't that only lifetime for the tires?
Old Mar 1, 2005 | 12:11 PM
BEJAY1's Avatar
Conecarver
Firestone lifetimes are a great deal. I've already used mine 3 times since last fall. Before that it was JustTires 8 x $59 ea. Just make sure their equipment is newer/can handle lowered cars if that's your case.
Old Mar 1, 2005 | 12:34 PM
$tillenmax2k
Separate the hub from the lower control arm, not the strut. Keep your alignment settings.
Old Mar 1, 2005 | 12:55 PM
SkoorbMax's Avatar
Is this difficult? I've not read about that way of doing it anywhere else...
Old Mar 1, 2005 | 01:00 PM
nissan5788's Avatar
On a related note, is it necessary to get a "4 wheel alignment" done on or cars? I thought I read somewhere on here a long while ago that you only need to do a less expensive, 2 front wheel alignment on our cars...anyone know for sure?
Old Mar 1, 2005 | 01:07 PM
SkoorbMax's Avatar
I believe that's right. When I called big10 though I told him what car it was and still the $69 quote!
Old Mar 1, 2005 | 02:16 PM
$tillenmax2k
Separating the hub from the lower control arm simply requires removing a cotter pin and a 19mm nut. A balljoint separator may be needed, and can be loaned from Autozone or Kragen at no cost.
As far as alignment, you should argue until they settle on "2 wheel" only. If they insist on charging you for 4 wheel alignment, tell them you will pay for it when they show you where the adjustments are made in the rear. Nothing to adjust back there, don't pay for it.
Old Mar 1, 2005 | 02:46 PM
SkoorbMax's Avatar
I suspect they'll tell me to get my alignment done elsewhere then
Pnjboyzz
Oct 7, 2015 10:47 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
