Plus Size Confusion
Plus Size Confusion
I am upgrading from the stock 15's on my 93 SE to 17 x 7. Every tire shop I go to for a quote gives me the size 235 45R17 as the correct size. When I used 1010tire.com calculator it told me 215 50R17 kept the closest diameter and kept speedo the most accurate. What is the difference here? If any?
Thanks.
Thanks.
Thanks.
Thanks.
The 215/50 tire is narrower, with a taller sidewall. The overall diameter is probably very close to the 235/45. Honestly, with a 7" width, I would get a 225/45 tire. You are still within the 3% tolerance (putting a 235 width tire on a 7" wide rim is not recommended by alot of manufacturers). Hope that helps.
Thanks.
Thanks.
Personally a 7" wide rim is a little narrow, you should go with a 225, you could run 235 but that is pushing it. Since you are spending the money to get rims, go with a 7.5 or 8" wide and a nice 235, also, if you plan on going big brakes, make sure you get a lower offset and wheels that will clear.
knight_yyz
Nov 1, 2015 01:34 PM
