235/55/17?
Old Mar 13, 2005 | 11:26 PM
Zaypka's Avatar
235/55/17?
Does any 1 knows how the car will look and handel on the road with 235/55/17 tire size? 235/45/17 is kind a bumpy for me and it looks bad on a stock car.
Old Mar 14, 2005 | 03:30 PM
NisMoN00B's Avatar
+Cru OG
55s will rub on your fender. stick with the 225/50. if you're gonna go wide, you can fit the more expensive 235/50 tires.
Old Mar 14, 2005 | 04:15 PM
NmexMAX's Avatar
dot dot dot ...
Look wierd and handle worse. (IMO)
The sidewall will be pretty tall, and hurt performance.
The speedo will be off by a bit (5%)
If looks and performance are an issue, lower it and get 235/45-17's
Old Mar 15, 2005 | 05:16 AM
expressinme's Avatar
the handle is no different from the 235 45 17
Old Mar 15, 2005 | 11:17 PM
NmexMAX's Avatar
dot dot dot ...
That's your opinion, and the other was mine.
Tdinero931
Wheels/Tires
May 31, 2013 08:37 AM
icemanf14d
Sep 25, 2009 08:17 AM
bgates1654
Tires and Wheels
Oct 28, 2005 01:02 PM
CJ7
Tires and Wheels
Aug 21, 2005 09:45 AM
