Will a +45 offset look decent on my 4th gen?
Old Mar 18, 2005 | 11:03 AM
jwmaxse's Avatar
I'm looking at a set of used, cheapo 16" wheels and the owner thinks they have a +40 or +45 offset. He has newer eclipse turbo and they come all the way out to the wheel well on his car and I know it's a +46 stock. My question is, what is the stock offset on the 4th gen maxima and will a 35, 40, or 45 look decent.
Here is a link to the wheels that I'm looking at:
http://chicago.craigslist.org/car/64344103.html
Old Mar 18, 2005 | 05:19 PM
z32drifter's Avatar
it depends on the width of the wheel.... +45 is close to stock offset I think... I can tell you what looks good on my car from the wheels I have tried.... 17x9 +34 looks great on the rear.... but sticks out a few mm in the front.... 17x8.5 +40 looks great on the front ..... 17x9.5 +38 won't clear Z brakes on the front but looks good on the rear... 16x7.5 +45 looks like it should be factory
check my webshots site below.... first set is Z32 wheels 16x7.5 +45 second set is Enkei RPF1 17x8.5 +40 and 17x9.5 +38 (street wheels for my Z) last set is Halibrand CobraIII 17x9 +34 (track wheels with R compounds)
Old Mar 18, 2005 | 05:43 PM
1FSTMAX's Avatar
look at sig.. 48mm offset..
Old Mar 19, 2005 | 01:01 PM
jwmaxse's Avatar
Alright, the offset is actually +35 and they are 16x7 rims so I think they would look decent. I guess they would look about the same as the Z32 rims because they would stick out 10mm more and are about 13mm more narrow. Am I right in thinking that they would be about 3.5mm closer to the edge of the car? [10-6.5(13x.5)=3.5]
Edit: Duh, I just remembered about the wheel calculator. It should come out to the edge by about 4mm more than the Z32 wheels so they should look decent. Thanks for the help guys.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
