What is high & low Offset?
Old Mar 18, 2005 | 10:26 PM
samssen's Avatar
my stock 17" stock rim is high Offset, so 45 is high or 35 is high?
thanks
Old Mar 19, 2005 | 05:24 AM
Ammi's Avatar
350 Detroit Muscle
Positive Offset
A positive offset occurs when the hub mounting surface is on the street side (the side you see) of the center line of the rim. Most factory rims will have this type of offset.
Zero Offset
When the hub mounting surface is centered within the rim, it is known as a zero offset.
Negative Offset
If the hub mounting surface is on the brake side of the center line of the rim, it is considered a negative offset or "deep dish".
In other words, lower the offset, further wheels stick out.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
sliptap
Sep 30, 2015 05:57 AM
Sep 27, 2015 08:37 AM
