Offset Question?
Old Apr 14, 2005 | 06:05 AM
browne's Avatar
Offset Question?
what is the offset for 98 stock se rims? and also will 17x7 with an offset of 42 fit 98 maxima?
does higher the offset mean that the rim will go more inside the wheel well? thanks.
Old Apr 14, 2005 | 06:51 AM
96 Max SE's Avatar
More + offset means the wheels goes into the wheel well. Negative offset pushes the wheel out away from the car. Check tire rack you should be able to firgure out stock offset there.
Old Apr 14, 2005 | 06:53 AM
96 Max SE's Avatar
I looked up a 16x7 a while back at tire rack and it listed the offset needed as +40 mm. So +42 should fit. Thats less than 1/10" difference.
Old Apr 14, 2005 | 07:12 AM
96 Max SE's Avatar
One last thing, if you go to tire rack, I think you need to add the rims to your shopping basket and then the offset will show up.
Old Apr 14, 2005 | 03:30 PM
browne's Avatar
thanks for the info.
Old Apr 14, 2005 | 07:35 PM
$tillenmax2k
DO NOT buy wheels narrower than 8" wide. If for some ungodly reason you do, the offset should be between 30-38mm to look and handle decent.
Old Apr 15, 2005 | 11:51 PM
browne's Avatar
what?... i got 17x7 rims with 40 offset and there running fine. i was thinking of getting new rims 17x7 with 42 offset and was wondering if they will fit ok.
Old Apr 15, 2005 | 11:55 PM
yamehoo's Avatar
Please dont give false information, I'm running a set of SSR Integral A2 17x7 with +45mm offset and they are perfect for 4gen. They're even clear my Gran Turismo big brakes kit with a 5mm spacer.
Old Apr 16, 2005 | 02:01 PM
Dave H.'s Avatar
I plan on getting 17x7.5 with an offset of 45. Would that work without clearance problems? By the way, they will be Rota Subzero's.
Thanks.
Old Apr 16, 2005 | 02:34 PM
VIP Maxima
so what would a 19x8 with 245/40/19 and a 40mm offset look like. sitck out, stick in or perfect?
Old Apr 16, 2005 | 02:37 PM
$tillenmax2k
Depends on the drop. But with a decent setting on your coilovers, the fronts will be perfect, and the rear will be OK but could use a 5 or 10mm spacer to look even better.
Old Mar 3, 2011 | 02:29 PM
DAGODSON03's Avatar
what the offset for a 2003 maxima se
Old Mar 6, 2011 | 07:38 AM
Tmars's Avatar
Stock 2003 SE Rims should be 17x7 +45mm offset.
Old Mar 23, 2011 | 02:12 PM
LtnMAXX's Avatar
anyone can shoot me a PM, wats the offset on a stock 99 SE? TIA
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
