19x9.5"...
Old May 30, 2005 | 01:54 PM
1FSTMAX's Avatar
19x9.5"...
bored today.. tried my brothers wheels on my car. I thought that 19x9.5 wouldn't fit, but they do. The tires are 275/30/19 in the rear, and 255/35/19 up front. Here are some pics...
Old May 30, 2005 | 02:18 PM
4x4Max's Avatar
looks badasss! makes it look like its RWD because of the bigger rim on the rear
Old May 30, 2005 | 03:47 PM
'96MaxGLE's Avatar
What offset r those wheels? Do u have any suspension upgrades on ur max?
Old May 31, 2005 | 11:03 AM
1FSTMAX's Avatar
eibach springs over koni's, the wheels are 19x8.5" up front, and 19x9.5" back both with 35mm offset..
Old May 31, 2005 | 02:08 PM
Royal_T's Avatar
Man that is just sick! I wonder if the 19x9.5 will fit the front? I might just do this setup on my car it looks good.
Old May 31, 2005 | 03:51 PM
'96MaxGLE's Avatar
I've been wanting to do a staggered setup on my 4th Gen for a long time, but can never get an answer on what offset to use. Thanks for helping me out!
Old May 31, 2005 | 06:27 PM
95bkackmax18s's Avatar
it does look really nice. that rims also has a nice lip.
Old May 31, 2005 | 11:15 PM
$tillenmax2k
They do bolt on to the car, but i wouldn't say they "fit". Did you try driving around with them for a while? I'm sure you would start hearing scraping and rubbing, especially on the highway. Looks good though, just need to lower the car. The Boss Chen pimp coilovers should solve that!
Old Jun 1, 2005 | 06:00 AM
Minimalmaxima's Avatar
I disagree, man. That car is tight as heck right where the height is. It looks like it's lowered already.
1FSTMAX, what kind of body kit is that on your car?
EDIT: $stillenmax2k, my bad if you were talking about the wheels that he actually owns, not the ones he put on that belong to his brother.
Old Jun 1, 2005 | 11:56 AM
$tillenmax2k
Actually, i was reffering to his brother's G wheels on his Maxima. They don't have the proper clearances to drive around without rubbing, and they stick out of the body a bit, which looks funky. The bronze wheels he owns are fine, they fit properly.
And he know's what I meant when i said it needs to be lowered. That's where the bad azz Boss Chen coilovers he's waiting for come in. It needs to be down to the ground like this car:
Old Jun 1, 2005 | 12:13 PM
Oh okay so that's how you like it. That's all good. But in the pic with his brothers wheels, it looks like his car is lowered already. Is it not?
EDIT: Okay I think this will be my last edit for the day. But 1FSTMAX you say you have eibach springs over konis, right? How much drop did you get with those?
Old Jun 2, 2005 | 12:44 AM
A33 VQ30DEK's Avatar
stillen kit like every other 4th gen out there.
Old Jun 2, 2005 | 04:47 AM
This kit looks different on almost every car I see. So did you buy it from $tealin? How much was the pain job? Did you put it on yourself? Does it screw or glue on? I'll do some searches.
Old Jun 4, 2005 | 04:01 PM
Ludacris's Avatar
Alfonso...do u know what the offset on those were? Im thinking of getting a set that are 18x8.5 front and 18x9.5 rear +38 offset. Not sure how itll fit tho..
jerrod99_se-l
Sep 25, 2015 03:02 AM
followthadollar
Sep 23, 2015 08:31 PM
Turbobink
Aug 15, 2015 07:20 AM
