Lugs and Stems
Old Jun 25, 2005 | 10:50 AM
Mystery's Avatar
Lugs and Stems
I've never actually bought rims or tires that didn't come with either of these, so now i'm stuck trying to figure out what i need. I bought 20 x 8.5 Dezenyo Mirage rims, with some Toyo Proxes 4 245/35/20. Any advice on where to buy these things? Or what exactly i am to ask for. Thanks in advance.
Old Jun 25, 2005 | 10:57 AM
irish44j's Avatar
retired moderator
lugs?? Since when do wheels and tires come with lugs? valve stems, yes...but just buy a wheel that has the same lug pattern as stock....
Old Jun 25, 2005 | 11:49 PM
boone's Avatar
You gon' pay what you owe
You should be able to go to just about any wheel shop and ask for a wheel install kit for your car. It should include lug nuts and valve stems. Make sure they give you the lug nuts that are closed on the top due to your wheel's design. Also, I'd pick up a set of hubcentric rings too. You'll need to get the center bore size for your wheels if the shop you go to doesn't carry your wheels.
Old Jun 26, 2005 | 02:24 PM
Mystery's Avatar
Thanks. I'll look into that next week.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
dcam0326
Sep 26, 2015 05:20 AM
03VQMAX
Sep 5, 2015 03:47 PM
metallic97gxe
Feb 24, 2001 12:49 AM
metallic97gxe
Jan 28, 2001 10:15 PM
