Dynoed car yesterday, kind of disturbed with the outcome
Old Jun 27, 2005 | 06:02 AM
2k1Maxdrvr's Avatar
Hey guys I'm sure someone can explain if this is in ballpark where it should be. Now keep in mind the temp yesterday was like 95 here. I have a 2k1 slightly modded with a catback exhaust and a short intake, the car only pushed 185 hp to the wheels. I was under the assumption that these have 230hp. Is there that much of a difference to the wheels than the crank?? I would think that it would at least put about 200 to the wheels but to my suprise it was much lower than I expected!!!!
Old Jun 27, 2005 | 06:07 AM
JClaw's Avatar
How heavy are your wheels?
jimmycapp's Avatar
222hp to the crank.
And yes there is a difference. Depending on wheather you have an auto or a stick you have over a 13% lose
Old Jun 27, 2005 | 06:11 AM
2k1Maxdrvr's Avatar
It is a 5 speed I did it in 3rd gear and the wheels and tires are very heavy I'm sure, they are 18".
Old Jun 27, 2005 | 06:15 AM
takkar's Avatar
For bedtime reading:
https://maxima.org/modules.php?name=30_comparisons
I have the anniversary edition and as you can see, I have the slowest car ever ( 17" OEM anniversary wheels)
Old Jun 27, 2005 | 06:30 AM
2k1Maxdrvr's Avatar
Wow that is definitly bedtime reading, thanks alot takkar!
Old Jun 27, 2005 | 07:00 AM
jimmycapp's Avatar
thats an excellent artical. Im going to the old mans house tonight and switching my wheels. See how much of a difference it makes.
Old Jun 27, 2005 | 08:06 AM
frankd121's Avatar
185 to the wheels sounds about right considering that you've got some heavy 18's on it....maybe if you've got extra money laying around you should get a set of lightweight wheels...
Old Jun 27, 2005 | 08:15 AM
upstatemax's Avatar
I know it is a bit off topic... how much does high heat and humidity affect performance??
My brother and I were having fun with one of the G-Tech meters and the best run I had was a 15.9, I have an auto 2000 SE with a GAB and Cattman Catback. It was also 98 and VERY humid, would that slow me down bad?
Old Jun 27, 2005 | 08:18 AM
JClaw's Avatar
Get stock GXE wheels (15" I believe) and put on DRs or slicks for the track while you're at it. That could be your "track" tires (only 2 for the front) and could you back 10+whp.
Old Jun 27, 2005 | 08:21 AM
2k1Maxdrvr's Avatar
Thanks for all the input guys I mainly just wondered if that 185 hp sounded right to you guys. You are all great guys and thanks alot!!
Old Jun 27, 2005 | 08:41 AM
NmexMAX's Avatar
dot dot dot ...
Are the numbers SAE corrected?
Old Jun 27, 2005 | 09:04 AM
VQ30GTR's Avatar
Bone stock my 2K1 Auto was 173/175. 222 from the crank from Nissan specs.
Old Jun 27, 2005 | 09:16 AM
S00NR1's Avatar
OU > *
Wow, that was one hell of an informative writeup. Now I have some actual numbers to prove my assumption that I had one of the slowest Maximas to ever come from the factory, especially now that I have the BlehmCo 6th gen rotor kit adding 10 lbs more to each front wheel.
Old Jun 27, 2005 | 10:17 AM
joebangaa's Avatar
de-k's make good power to the wheels. its sad that an auto 5.5gen only makes 10whp more, and that a 6spd just eats up your power
Old Jun 27, 2005 | 10:25 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if you want to compare numbers to most on here then dyno in 4th gear for 5spd and 3rd gear for our autos. dont listen to the dyno operators or go somewhere if they say otherwise. everyone at the maxus dyno should know this first hand.
Old Jun 27, 2005 | 10:30 AM
2k1Maxdrvr's Avatar
I did a 4th gear and it was 183. It was at a contest here in my area, I couldn't believe it a 04 SRT4 pulled a run and hit 425hp, then some dude pulls in in a rustbucket Ranger with a Thunderbird Super Coupe motor swap and pulled a 142 it was a riot!
Old Jun 27, 2005 | 10:34 AM
NmexMAX's Avatar
dot dot dot ...
They do have some beefy torque though.
Old Jun 27, 2005 | 11:13 AM
Ammi's Avatar
350 Detroit Muscle
whp and crack hp are different numbers.
did you do 3rd or 4th gear pull?
Old Jun 27, 2005 | 11:36 AM
2k1Maxdrvr's Avatar
yes did both and I knew they were different I just didn't think it was a 40-50hp difference or loss should I say. 3rd gear 185 4th gear 183
Old Jun 27, 2005 | 12:01 PM
Woody's Avatar
I just moved to reading. Where is this dyno ? I wanted to get some baselines.
Old Jun 27, 2005 | 12:14 PM
2k1Maxdrvr's Avatar
There is one at Koz's Custom Kars on Lancaster Ave in Shillington or one at East Coast Customs on Rt 61 in Shoemakersville
Old Jun 27, 2005 | 01:12 PM
E55AMG2's Avatar
Wat
DE-K's with a 5 speed FULLY modded put down between 4-8 whp more than a stock auto 5.5 gen.......200-204whp vs 196.
Driveline losses
5MT = 15%
6mt = 18%
4at = 23%
dunno where you get your info from...you might wanna slap that person though
Old Jun 27, 2005 | 01:20 PM
takkar's Avatar
I agree with E55AMG2...6mt has the least amount of losses and should have the best numbers on the track ( if you know how to shift).
Lighter wheels help a lot. I can feel so much of a difference between my 17"OEM wheels as compared to my winter tires which are 16"steel rims.
Old Jun 27, 2005 | 01:23 PM
niceguy's Avatar
E55 is exactly right on the drivetrain loss numbers.....5 years ago I took my '93 Altima to a dyno here in Memphis and put down around 115whp, which was a 23% loss...so little to no difference between the losses of Nissan auto trannies in the last 10-15years....
Jeremy
Old Jun 27, 2005 | 01:25 PM
E55AMG2's Avatar
Wat
Originally Posted by takkar
I agree with E55AMG2...6mt has the least amount of losses .
5MT does @15%......6MT loses 18%
Old Jun 27, 2005 | 02:28 PM
joebangaa's Avatar
what'd i say, all i meant was it'd be nice if the 6spd was no more than 15% like a typical fwd manual tranny
Old Jun 27, 2005 | 03:29 PM
BeSeenWithGreen's Avatar
Do th 16" rims fit on a 2002 SE?
Old Jun 27, 2005 | 03:36 PM
NmexMAX's Avatar
dot dot dot ...
The 2002+ GXE has 16's so my guess would be yes ....
Old Jun 27, 2005 | 06:15 PM
E55AMG2's Avatar
Wat
Some 15" even fit
Old Jun 27, 2005 | 07:58 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Driveline losses
5MT = 15%
6mt = 18%
4at = 23%
I tend to dissagree. Show me a dyno of a real fully loaded with every mod 5spd DE-K and light 15-17lbs wheels and stock brakes. Till then this post of yours is worhtless and full off BS info.
Old Jun 28, 2005 | 09:56 PM
E55AMG2's Avatar
Wat
Can you host pics, Ive got runfiles from a 2000 5spd with full bolt ons and stock wheels. Ill be more than happy to send them over if you'd like. If you want a dyno of what you described..post your dynos up
Old Jun 28, 2005 | 10:40 PM
sooner02r1's Avatar
Yes. The last trip I took to the track, it was like 95 degrees and really humid and everybody was claiming to be .4 slower than with cooler temperatures. That would be about right because I ran a 14.90 when I should be around 14.50-14.60.
Old Jun 29, 2005 | 11:38 AM
Maximax2's Avatar
5.5's get their advantage in acceleration mostly from tq, not high-end hp. That's why they're relatively quick off the line, but the advantage fades on the highway (stock).
Old Jun 29, 2005 | 01:43 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
http://forums.maxima.org/showpost.ph...&postcount=157
Originally Posted by IceY2K1
Here is a 2001 5spd with an absurd correction factor(Honduuh ricer shop inflates numbers by modifying altitude), light weight yet 19" Centerline rims, Cattman headers, JWT POP, high flow cat, Frankencar high flow Bpipe, and no axle back section, here are his numbers with NO tuning:
Now show me YOURS....
Old Jul 1, 2005 | 02:19 PM
liqidvenom's Avatar
brotherhood of tq
im still at a lose to understand how heavier wheels would have a negative readout on a dyno. i would see how rims would hurt accel but how would it make the dyno read a lower number.
Old Jul 1, 2005 | 02:34 PM
E55AMG2's Avatar
Wat
More rotational mass = more inertia= more power used to overcome that inertia, therefore leaving less power available for acceleration. Thats the simple version
Old Jul 4, 2005 | 07:02 PM
Another problem with dynoing cars is aligment issues, if your car has too much toe in or toe out it will hurt your dyno #s also. Since it takes energy to push the car forward- if the tires are scrubbing inward (toe in) then it takes more energy to overcome that force. There are alot of factors as to why one car can make XXX amount of power, where another car makes less or more.
Old Jul 4, 2005 | 08:37 PM
E55AMG2's Avatar
Wat
It would have to be pretty severely in or out to make a significant difference
Old Jul 4, 2005 | 08:44 PM
From personal experience 1.5 deg of toe IN on a B13 w/ NA SR20 will make around 5-6WHP diff, which will make some people scream bout their car not performing up to specified horsepower levels. Its not like they have the time to perfectly align every car at the factory, it only takes a few min to build the car. Its normal to see cars out of aligment straight from the factory.
