Lug nuts: open vs closed
Old Jul 8, 2005 | 01:11 PM
mm347's Avatar
What's the difference between open ended and closed lug nuts, which are better for aftermarket rims?
Open ended:
OR
Closed:
Old Jul 8, 2005 | 01:54 PM
addicted2sp33d's Avatar
Personally, I like the open lugnuts, because you can run longer wheel-studs, and insert spacers to adjust track-width for a wider stance at the track, and then remove them when you don't want them for street (wide track and wide tires make the car VERY sensitive to grooves in the road).
Old Jul 8, 2005 | 02:02 PM
BEJAY1's Avatar
Conecarver
Agreed - 0pen give you more options. I suppose closed would look better and slow rain/snow from getting at the lug bolts some.
Old Jul 8, 2005 | 06:51 PM
Ammi's Avatar
350 Detroit Muscle
unless you are planning on upgrading to longer studs, closed lugs should be fine
Old Jul 8, 2005 | 08:17 PM
mm347's Avatar
I'm not planning on getting longer studs, it's just that the open-ended lugs pictured above are slightly cheaper and lighter.
$29.99 for Muteki open-ended - http://cgi.ebay.com/ebaymotors/ws/eB...985662135&rd=1
$39.00 for closed - http://cgi.ebay.com/ebaymotors/ws/eB...category=33749
Old Jul 9, 2005 | 04:25 AM
Bluesbrekr's Avatar
Doctorate in Detailing
I have the closed-end. McGuard spline drives.
I didn't like the fact that the open-ended ones start to rust after a while. (especially the chrome ones)
Old Jul 9, 2005 | 08:32 AM
jmeister's Avatar
It's not so much that the open ones rust but the studs do and it runs all over the lugs. Looks like crap, at least mine do. But due to the type of rims I have, open is my only option.
Old Jul 10, 2005 | 03:17 PM
04BlackMaxx's Avatar
I live within walking distance from McGard. I cant believe they have such an awesome building and make so much money just by making lugs.
Old Jul 11, 2005 | 08:57 AM
aznsap's Avatar
open ones are lighter = less unsprung weight
i have open ones and personally the stud rust is there and noticeable upon close inspection, but doens't really harm anything.
Old Jul 11, 2005 | 07:49 PM
mm347's Avatar
That's because they charge $70-100 for a set of lug nuts
Old Jul 11, 2005 | 09:06 PM
Ammi's Avatar
350 Detroit Muscle
That's not bad considering how much I had to pay for my Volk lugs
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
mkaresh
Mar 12, 2018 06:48 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
