Most Aggressive offset
Old Jul 21, 2005 | 08:57 AM
Royal_T's Avatar
I'm in the market for some new set off rims. I narrowed it down to two types of rims Gold SF-Challenge and Gold SF-Winnings. My question to you'll is what is the most aggressive offset a 4th gen can use on 19x8.5 front and 19x9.5 rear. I will also roll my fenders if needed. Any help would be great.
Edafe
Old Jul 21, 2005 | 02:28 PM
Royal_T's Avatar
BUMP, ANY help please
Old Jul 21, 2005 | 04:48 PM
$tillenmax2k
It depends on what size tire you are going to use. Wider tires will severly limit your choices.
Old Jul 21, 2005 | 08:11 PM
Royal_T's Avatar
How about 275/30/19 in the rear19x9.5, and 255/35/19 up front19x8.5 or do I have to go smaller.
Old Jul 22, 2005 | 12:57 AM
$tillenmax2k
You're gonna have to go with narrower tires. 235/35 up front on the 8.5", and 255/35 on the 9.5" rears.
If you go with the SF Challenges, you need 19x8.5 Offset Type "A" +34mm with rim depth of 50mm for the front, and 19x8.5 Offset Type "B" 36mm with rim depth of 69mm for the rear.
For the SF Winning's (which IMO are not as nice) you will need 19x8.5 Offset Type "A" +38mm with rim depth of 36mm for the front, and 19x9.5 Offset Type "B" +42mm with rim depth of 55mm for the rear. These wheels are heavier, and will have a smaller lip, so stick with the first ones.
Old Jul 22, 2005 | 05:50 AM
Royal_T's Avatar
Thank you so much. Yea I think I'm going to go with the Challenges they were my first choice so I guess I'll stick with that. So I would need 19x8.5 offset type "A" +34mm w/235/35tires up front and 19x9.5 Offset Type "B" +36mm w/ 255/35tire on the rears.
Thanks again
Edafe
Old Jul 22, 2005 | 05:51 AM
Ammi's Avatar
350 Detroit Muscle
245s front and 275s rear
Old Jul 22, 2005 | 06:01 AM
Royal_T's Avatar
With 245s front and 275s rear will they rub or do I have to roll my fenders?
Old Jul 22, 2005 | 08:47 AM
icelandmaxima's Avatar
Maxima Fanatic
It wouldnt hurt to have the fenders rolled just have it done right.
Old Jul 22, 2005 | 09:30 AM
$tillenmax2k
245's won't fit right in the front with those offsets, since you want aggresive offset and more lip. 275's will hardly fit, and would require a wheel with much higher offset to avoid shredding the outside of the tire, and 275 should be mounted on a wider wheel anyways.
That setup is what i'm using, but my wheels don't have as much lip as i would like.
Old Jul 22, 2005 | 09:33 AM
Ammi's Avatar
350 Detroit Muscle
More than enough room to mount 275s on 9.5" wide wheels
Old Jul 22, 2005 | 09:44 AM
$tillenmax2k
Not quite, as it leaves the sidewalls a bit flimsy. 10-11" would be best. Also, a 245 or 255 on the 9.5" will show off the lip better.
Old Jul 22, 2005 | 03:52 PM
Ammi's Avatar
350 Detroit Muscle
Does not leave flimsy sidewall. I've been running 245s on 8.5" for long time and I've seen many people running 255s on 8.5". Take a look at BLKMAX005SPD's old Max and tell me if his rear sidewalls look flimsy
Old Jul 22, 2005 | 08:28 PM
gunmax's Avatar
I am running 18x8 with 245/40 with a 41 offset and the rears are 18x9 with 245/40 with a 37 offset. no problems.
RinconI30
Jun 11, 2016 08:25 PM
lux97Max
Sep 28, 2015 11:18 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
