painting rims......
Old Sep 19, 2005 | 10:42 AM
maxspeed96CT's Avatar
The original VQ...
painting rims......
How difficuilt is it to paint a set of rims?
My 19's have alot of nic's on them and i want a darker color rim (gunmetalish)to match my car beter
Can this be done at home and still come out good?
What kind of steps does it involve and what would i have to do to prep them?
Whats the best paint to use?
Do i have to diss-mount the tires?
Any tips or info is welcome..
Old Sep 20, 2005 | 08:36 AM
Ammi's Avatar
350 Detroit Muscle
check the faq. there is a guide on how to paint your rims.
Old Sep 21, 2005 | 02:29 PM
Battle Max's Avatar
you can paint them but personally in the long run it may be better off getting them powder coated. Either way it will look good but i believe in doing things right the first time even if it may cost a little more.
Old Sep 21, 2005 | 06:49 PM
MDeezy's Avatar
some have done it themselves at home with tires mounted and about $20-$40 in paint and prep material and its lasted a good 6 months no flaws.
Check the how to's as suggested the method is in there.
Old Sep 21, 2005 | 09:22 PM
The original VQ...
how much wuld it cost, and would any paint shop be able to do it?
I do want to do it right but i just dnt want to spend alot of money
Old Sep 21, 2005 | 09:24 PM
MDeezy's Avatar
If you dont want to spend alot of money dont send your wheels to the shop. I dont know how much powder coding is or just regular wheel painting but they will want to unmount the wheel, then prep work, painting, it will be a pretty penny.
Old Sep 29, 2005 | 10:57 AM
icelandmaxima's Avatar
Maxima Fanatic
The range for powdercoating is $60-$100 a rim depending on the shop and size/style of wheel. Well worth in it the long run though.
Old Sep 29, 2005 | 11:00 AM
Jeff92se's Avatar
I'm needing a caw
Paint will never match the durability of either the factory coat or an aftermarket powder coat. If you have nicks etc.. on your current wheels, you will get them even faster with only paint.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
Luigi623
Sep 21, 2015 01:42 PM
