Best offset for 01 Max?
Old Oct 10, 2005 | 03:47 PM
nadeemp8's Avatar
Hi folks, I'm thinking about buying some new rims and was wondering what offset I should be on the lookout for. The wheels are 18X7 with an offset of 44MM. Will these fit my car and look ok or not? Also the bolt pattern is 5-4.5. Please let me know ASAP as the auction on ebay ends in 24 hrs.
Thanks in advance!!
Old Oct 10, 2005 | 05:54 PM
soundmike's Avatar
Very sound, Mike
A 7" wide rim at 44mm offset will tuck-in just like the OEM rims (45mm offset). If you're looking to have the fenders line up with the rims you're better off with a lower offset - 35mm 8" wide rim is a good place to start. You can also do a 7.5 at the same offset or lower.
18x7's will be a bit skinny but will still work either way.
Old Oct 11, 2005 | 07:29 AM
nadeemp8's Avatar
Awesome, thank you very much!!
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
