Tire size with no issues....
Old Nov 11, 2005 | 09:17 AM
culejoe's Avatar
Hey i have the stock tire size.... 215/55/16 has anyone went from that to 255/50/16 and had any issues with rub or anyting or even 255/60/16??? thanks
Old Nov 11, 2005 | 08:26 PM
z32drifter's Avatar
The 255s are going to be taller than stock. What size rims are you using??? you can't run 255s on stock SE wheels... 225/50/16 is pushing it for the stock rim. However 255/50/16 is .7" taller than stock 255/60 is 2.7" taller. I think the 255/50s could fit on the proper rim.
Old Nov 12, 2005 | 09:45 AM
culejoe's Avatar
yea im running stock rims 15 or 16 they are the 5 spoke ones and the tire says 215/55/16 16 represents the size right? so thats what im currently running on stock rims...
Old Nov 12, 2005 | 10:07 AM
z32drifter's Avatar
the stock SE wheel is 16x6.5 if you want a larger tire for the stock wheel you have 2 to pick from. 225/50/16 is wider and about .5" shorter. I've used this setup and had no problems. 235/50/16 is wider and the same height as the stock tire..... only problem is 235s are hard to find and more expensive. the 235 is the max recomended for a 6.5" wheel. Rule of thumb is to keep the tire section width under 2" larger than the wheel width. The 255s you ask about are over 10" in section width. I like to keep the tire around 1" larger that the wheel ..... but thats me.
Old Nov 12, 2005 | 01:00 PM
culejoe's Avatar
my appoloiges i ment 235**/55/16 whats different between 225/50/16 and 225/55/16 and u have had no rubbing issues? i have a gxe but i have the stock se alloy rims....
Old Nov 12, 2005 | 04:47 PM
z32drifter's Avatar
225/55 is .4" taller than stock... it's .8" taller than a 225/50... 235/55 is .9" taller than stock. At stock ride height you won't rub with either tire, however I think the taller tires make the car look kinda like 4X4 .... the 225/50s make the stock fender gap look HUGE so 225/55 might be the ticket.
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
