Hankook Ventus Hrii H405 anyone?
Old Dec 6, 2005 | 04:35 PM
TwoToneMax
Just curious if anyone has these tires 225 50 17 on there Maxima comments likes dislikes?
Old Dec 7, 2005 | 06:50 AM
igzy's Avatar
I Know Kwaliti
I had a set of them on. I though they were a decent tire with good dry and wet performance and the price was right If you do get a set, just keep in mind that they will need to be kept at 38 psi...
Old Dec 7, 2005 | 08:31 AM
CCS2k1Max's Avatar
i.e., they have very loosy goosy soft side walls.
Old Dec 7, 2005 | 08:39 AM
igzy's Avatar
I Know Kwaliti
Not really, that is not necessarily the case... Max load rating on them was around 50 psi (I'll see if I can find specs somewhere) so to get most of them, I kept it at 38 psi...
Old Dec 7, 2005 | 09:17 AM
igzy's Avatar
I Know Kwaliti
I found that it was handling very in tight corners at high speeds with no sliding... Found the specs: http://www.hankooktire.ca/pdf/12.pdf
Maximum rating is 44 psi...
MAXSE5SPD
Aug 23, 2015 12:06 PM
Doc
Tires and Wheels
Apr 4, 2005 08:44 PM
dinograz
Tires and Wheels
Oct 6, 2004 10:40 AM
skyjay617
Jun 26, 2003 06:56 AM
