g35 on a 6th gen
Old Dec 18, 2005 | 07:04 AM
VQMAX05's Avatar
g35 on a 6th gen
Real quick do the 19" Rays wheels of the 05 g35 coupe fit the 6th gen without a problem?? has anyone done this?
thanks
jon
Old Dec 18, 2005 | 08:01 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
usually RWD wheels don't fit FWD cars...
Old Dec 18, 2005 | 09:28 AM
KCMAXX's Avatar
KC's FINEST
Sure they will, tek arent yours from a SUV fitment?
Jon, still have the tires?
Old Dec 18, 2005 | 02:55 PM
Tek-Niq's Avatar
yea, but I think they are 2 pairs of just the front side, not rear..
A member on another fourm just bought a set of RWD wheels and had to sell them cause they didn't fit of the max, thats why I say this..
Old Dec 18, 2005 | 03:19 PM
factorymax's Avatar
I have seen pics of G35 coupe wheels on a Maxima posted on this forum before. They looked great.
Old Dec 18, 2005 | 03:23 PM
Tek-Niq's Avatar
I think you're right, I remember something like that... It might be 22" wheels I'm talking about cause thats the size that didn't fit in RWD..
Old Dec 18, 2005 | 03:25 PM
viguera's Avatar
It depends on whether they're staggered or not. All (that I know) FWD cars run non-staggered setups by default, so most won't have room in the rear for wider wheels/tires. Most (decent ) RWD cars will come with staggered setups, where the rears are sometimes up to 1" wider than the fronts, so there's all kinds of fitment issues.
Old Dec 18, 2005 | 03:27 PM
KCMAXX's Avatar
KC's FINEST
I had a set of 17" Z wheels on my max that were staggered and they fit great. Just didnt look right. It sucks getting used to 20's..
Old Dec 18, 2005 | 07:47 PM
VQMAX05's Avatar
I have on my Max right now a staggered set of wheel. 18 x 8 front 18 x 9 rear. With 38mm offset and 2" lip in the front 3" lip in the rear. Looks great.
Black centers with chrome lip. (not polished or machined) chrome!!
I ask if the g wheels will fit b/c i like the OEM 19's of a 05 G35.
Old Dec 19, 2005 | 02:47 PM
pkane3's Avatar
I've got the G35 Rims on my Max. I get more compliments about the rims than anything else.
Old Dec 23, 2005 | 08:41 PM
KCMAXX's Avatar
KC's FINEST
Those look good, are they the 17's or 18's? Also post a few more pics
Old Dec 23, 2005 | 09:32 PM
Glude's Avatar
Those would be 18s. They look nice too!
Old Dec 28, 2005 | 08:17 PM
moo moo's Avatar
Yes, more pics!
Old Jan 7, 2006 | 03:46 PM
02theMax's Avatar
I just bought a set of 05 g35 rims staggered. 19x8 up front and 19x8.5 out back. 225/40/19 front 245/40/19 rear I'll post pictures and fitment issues once they arrive.
Old Jan 7, 2006 | 05:24 PM
808MAX-SPEC's Avatar
Complete Specs on the G35 coupe 19"s. Hope this helps.
-THE WHEELS-
Specifications:
Rays Racing Volk
Diameter: 19"
Width: Front Rim: 8" Rear Rim: 8.5"
Bolt pattern: 5 x 114.3
Finish: silver polished
Offset: Front: 30 Rear: 33
-THE TIRES-
Specifications:
Brand & Model: Bridgestone Potenza RE 050A
Dimensions: Front Tires: 225/40R19 Rear Tires: 245/40R19
Treadwear (longevity) rating: 140
Traction rating: A
Temperature rating: A
Old Jan 7, 2006 | 06:38 PM
02theMax's Avatar
Thanks 808max do you think they'll fit ok? I just bought progress springs for my 02 but was thinking that the tires might rub. If they don't fit maybe I'll just drop the front and leave the back stock height. Any thoughts?
Old Jan 7, 2006 | 09:48 PM
You can try that setup if you think it's going to prevent from rubbing. I've seen guys running 19x8.5fr and 19x9.5rear and they said no rubbing. Give it a try. Don't forget to post pics.
Old Jan 8, 2006 | 06:27 AM
Tek-Niq's Avatar
I have 22x9's on my car with minimal rubbing. with the 255/30/22 tire's it make the diameter of the whole wheel 24", and it fits in there nice even with a 2" drop in the front. it only rubs cause of the width of the rim being 9" only on "U" turns..
your 19's are ok..
Old Jan 8, 2006 | 09:11 AM
02theMax's Avatar
I was just worried about the 40 series profile of the tire rubbing. We'll see I guess, thanks for the replies I'll try to post pics this week sometime.
Old Jan 8, 2006 | 01:43 PM
Tek-Niq's Avatar
40 series are about an inch taller than a 30. with 19's you are about 22 inches round with tire, thats the same diameter as the stock 18 set up. you are runing 8" wide in the front, thats ok when turning.
you won't rub, unless you drop way low in the front. the rear is ok also, max blue runs 20x10 in the rear dropped on eibach springs and he's fine.
Old Jan 13, 2006 | 08:07 AM
zebpwgc's Avatar
will the 2006 SL wheels/tires fit on the 2006 SE?
zebpwgc's Avatar
Old Jan 13, 2006 | 08:57 AM
Puppetmaster's Avatar
Yes.
How many times do you have to post this?
http://forums.maxima.org/showthread....tpost&t=447045
http://forums.maxima.org/showthread....tpost&t=448006
Old Jan 13, 2006 | 09:01 AM
zebpwgc's Avatar
Thanks for the helpful response Puppetmaster.....
I appreciate it.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
hot04
Sep 18, 2015 06:14 AM
