Anything stronger than Aircraft Paint Remover?
Old Dec 29, 2005 | 07:08 AM
ChromeSE5's Avatar
I sprayed a bunch of aircraft paint remover on my rims that I just bought and the paint just won't come off like it does in the 4th gen write up. The paint just sticks and most of the paint I have removed is due to the sanding attachment I have used in conjunction with my drill. Any other chemicals or techniques? I thought about sandblasting but I fear pitting and also that this is suppose to be another cheap project.
Old Dec 29, 2005 | 07:27 AM
CCS2k1Max's Avatar
If all else fails, glass bead blasting is less harsh than sand blasting.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
