Need help calculating offset
Old Jan 3, 2006 | 06:59 AM
MacAlert's Avatar
Ok this might get a little confusing:
I have a 5.5 Gen running stock wheels at the moment.
I was looking to get either 8" or 8.5" wheels. I also have 20mm spacers in the rear and 5mm spacers in front. Which offset would I need to purchase so that the wheels (8" or 8.5") would fit?
Old Jan 3, 2006 | 12:38 PM
ChromeSE5's Avatar
with or without rubbing? Are your fenders rolled?
Old Jan 3, 2006 | 12:42 PM
MacAlert's Avatar
No, fenders are not rolled. I would prefer no rubbing.
Old Jan 4, 2006 | 04:17 PM
MacAlert's Avatar
Anyone?...
Old Jan 4, 2006 | 05:04 PM
irish44j's Avatar
retired moderator
check sticky #4 above.
IIRC if you get 8" wheels, get them all in 30 offset and get rid of all the spacers entirely.
Old Jan 4, 2006 | 08:46 PM
MacAlert's Avatar
Don't want to get rid of spacers....don't have the old wheels studs.
Old Jan 4, 2006 | 09:05 PM
C3nthusiast's Avatar
Wheel studs are $1 each. Take less than an hour to change them all if you have an impact. I run 19 X 8.5 front 235/35-19 and 19 X 9.5 rear 245/35-19 with no rubbing. I have AGX and Tein S techs on my 4th gen. The 5th gen has much more room in the wheel wells.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
