stock vs. mille miglia 17"
Old Jan 24, 2006 | 12:07 PM
Cdg2125's Avatar
Anybody know the difference between weights between the stock rims and the Mille Miglies EV-S 17" Rims? What needs to be changed in the car if i get the 17"?
Old Jan 24, 2006 | 03:47 PM
NmexMAX's Avatar
dot dot dot ...
Nothing needs to be changed. A drop would be nice, but isn't mandatory.
Not sure on the weights, but what wheels do you have on there now?
Stock SE's (16), 97+GLE 15" Sawblades, GXE steelies
Old Jan 24, 2006 | 06:07 PM
Cdg2125's Avatar
I've got stock 16's on the car now. i didnt know if anything needed to be changed in the engine or anything. I was told once that you had to change the computer or something because the bigger tires would affect the speedometer or something. That bogus?
Old Jan 24, 2006 | 07:39 PM
NmexMAX's Avatar
dot dot dot ...
Why would the tires be bigger?
Educate yourself by READING the STICKYS in this forum.
then go to www.tirerack.com and then www.discounttiredirect.com
Cliffs---> If you get the correct size tire, it should be within spec re: to your stock overall diameter and wont change a thing.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
