17" G35 tire size?
Old Feb 5, 2006 | 09:06 AM
NoMax...yet's Avatar
17" G35 tire size?
So I have a set of 17" G35 wheels. The tire sizes are 235/50 and 225/50. The rears look really nice with the larger tire but I've read you can't use the 235/50 on the front due to tire rub(rim size also). What do you guys think about 225/55 up front? I know some guys are saying go 235/45 all around but that brings all the sidewalls down and I don't know that I'm digging the rubberband look on the front wheel already.
I guess I'm asking you guysto talk me out of the 225/55s. Worst case I'll just replace the fronts with stock size. 235/45s have to little sidewall for me (I think).
Opinions/advise?
Thanks,
James
Old Feb 5, 2006 | 11:05 AM
02theMax's Avatar
235/45s have almost the same sidewall as the 225/50s. If I were you I'd def do the 235/45s no question. The 225/55's are way too big, so are the 235/50s (the 225/55s look like a winter tire).
Old Feb 5, 2006 | 12:02 PM
Maybe I just like the way they fill the fender gap. I was planning on lowering, but after installing these wheels I like the look of the rear, but the front just looks to small with the tiny little tire, and the 235/45 is shorter(maybe not much, but already small).
I'll have look around for some photos to decide.
Thanks for the input.
Old Feb 5, 2006 | 12:15 PM
irish44j's Avatar
retired moderator
you can actually use the 225/50 front and 235/50 rear if you want. Unless you're slammed, you shouldn't have rubbing issues. I use those sizes for snow tires (came off a 350z)
Otherwise, if you want same 3 all around, go with 235/45
Old Feb 5, 2006 | 12:16 PM
irish44j's Avatar
retired moderator
by the way, there is an entire thread devoted to G35 wheels....look at the top of this section in the stickies - it's the first one.
Old Feb 5, 2006 | 12:22 PM
Don't worry I've scoured it checking with the recent posts and all. Actually the pics of the 5th gen with the 235/45s made me think I wanted a taller tire.
Maybe I'm just getting old!
Old Feb 5, 2006 | 01:06 PM
02theMax's Avatar
Haha, I wouldn't go as far as to say that you're getting old. It's just a personal preference for you to have a bigger tire. I'm already thinking of selling the Max for a G35 sedan and I'm 28.
Old Feb 5, 2006 | 01:40 PM
After looking around a bit the pics I thought were 235/45 were 225/45 so maybe I can do the 235/45. Also I sat and stared at the Max for a bit and I think part of the small looking front wheel/tire is the front tires are worn out, no edge left, just center tread.
Old Feb 5, 2006 | 08:12 PM
02theMax's Avatar
Yeah that could be part of the reason you thought the 235/45s were too small. Hope you make the right choice for yourself.
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
