Wheel size help 6th Gen
Old Feb 11, 2006 | 11:33 PM
daittech's Avatar
Does anyone know if the follwing tire size will have any problems (too wide)with a 6th Gen maxima?
Size 18x9.5
PCD 5x114.3
Offset 35
Also what size tire will be recommended.
Any help is appreciated. Thank you all
Old Feb 12, 2006 | 04:12 AM
CanadianMoFo's Avatar
Have you thought about using the wheel offset caclulator posted in the sticky at the top of this forum?
CM
Old Feb 12, 2006 | 08:09 AM
daittech's Avatar
I did and I couldnt figure it out so thats why I asked....I may get an answer today if I can find a decent tire shop open.
Old Feb 12, 2006 | 04:08 PM
Well you put in all the data you have, hit calculate and get:
The clearance from stut housing to the inside of the wheel will be 20mm LESS
The outside edge of the wheel will EXTEND an extra 30mm
Old Feb 12, 2006 | 08:21 PM
daittech's Avatar
Yeah but somehow i wasnt conviced or clear if they were going to fit or not..anyhow I got them installed today and they DO fit and there is no modification required. They look really nice.
Thanks to all that helped.
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
maximaham
Aug 20, 2015 10:23 AM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
