235's on a 7.5" wheel?
Old Feb 13, 2006 | 11:09 AM
LudeAEM's Avatar
I just bought a set of NA 300zx wheels which are 16x7.5. They have 225/50 tires on them, and judging by others, putting 235's on them shoudlnt' be a problem. Just wanted feedback if i could. Thank you in advance.
Old Feb 13, 2006 | 12:28 PM
upstatemax's Avatar
I have 235's on my 7" wide rims.
Old Feb 13, 2006 | 02:02 PM
CCS2k1Max's Avatar
The rim widths recommended for 235/50R16 tires are 6.5-8.5 inches.
Old Feb 13, 2006 | 02:08 PM
steven88's Avatar
Need A Light?
I'm sure you can even squeeze 245s on that 7.5 if you wanted too...
heck, stock 2k4 maximas have that setup...I don't see why you can't do it...
Old Feb 13, 2006 | 03:27 PM
CanadianMoFo's Avatar
6th gen OEM SE rims are 18x7.5 with a 245/45-R18 tyre. You should be able to put a 235 on there without any issue.
CM
Old Feb 13, 2006 | 03:54 PM
LudeAEM's Avatar
Thanks for the feedback gentlemen
Old Feb 13, 2006 | 06:02 PM
z32drifter's Avatar
here's your options 225/50/16... 235/50/16.... 245/50/16... or 245/45/16. The 245/45 is rec of 8" but I have seen alot of Z32s with them on the 7.5s. The 245/45s are 3/10s of an inch shorter than the 225/50s, so if your looking to colse the fender gap a little don't go for that size. The 235/50 is kind of hard to find and only limited brands. I was thinking of using the 245/50 next time.
Old Feb 14, 2006 | 07:04 PM
BlueC's Avatar
wat
Ive got 245s on my Q45 wheels (17x7.5" I think). Fits perfectly and doesnt look bad.
Old Feb 14, 2006 | 09:12 PM
NmexMAX's Avatar
dot dot dot ...
I have 235's on a 7" wide.
Old Mar 16, 2006 | 03:53 PM
pegasus1113's Avatar
which tires do you have in 235 on your stock wheels?
Old Mar 16, 2006 | 03:56 PM
HotshotVQ35's Avatar
toyo proxies 4 FTW! edgeracing.com
Old Mar 16, 2006 | 07:24 PM
NmexMAX's Avatar
dot dot dot ...
Kuhmo ASX.
Old Mar 17, 2006 | 05:37 AM
CCS2k1Max's Avatar
Fuzion Zri
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
