Toyo Proxes T1r
Old Mar 21, 2006 | 09:26 PM
kamski's Avatar
.org extraordinaire
Toyo Proxes T1r
help me choose,
STOCK IS THE FIRST ONE,
here is my data on speed, size, contact patch, and % speed diff.
Whats more important for performance? contact patch size or tire diameter?
Stock Tire - 245/45R18
Search Tires Tire 1 - 245/40R19
Search Tires Tire 2 - 255/40R19
Section Width: 9.64 in 245 mm
Section Width: 10.03 in 255 mm
Rim Diameter: 18 in 457.2 mm
Rim Diameter: 19 in 482.6 mm
Rim Width Range: 7.5 - 9 in
Rim Width Range: 8 - 9.5 in
Rim Width Range: 8.5 - 10 in
Overall Diameter: 26.68 in 677.67 mm
Overall Diameter: 26.71 in 678.43 mm
Overall Diameter: 27.03 in 686.56 mm
Sidewall Height: 4.34 in 110.23 mm
Sidewall Height: 3.85 in 97.79 mm
Sidewall Height: 4.01 in 101.85 mm
Radius: 13.34 in 338.83 mm
Radius: 13.35 in 339.09 mm
Radius: 13.51 in 343.15 mm
Circumference: 83.81 in 2128.7 mm
Circumference: 83.91 in 2131.3 mm
Circumference: 84.91 in 2156.7 mm
Revs per Mile: 779.6
Revs per Mile: 778.7
Revs per Mile: 769.5
Actual Speed: 60 mph 100 km/h
Speedometer1: 59.9 mph 99.8 km/h
Speedometer1: 59.2 mph 98.7 km/h
Speedometer Difference: -
Speedometer Difference: 0.115% too slow
Speedometer Difference: 1.312% too slow
Help! need to buy a new set of rubbers, dont know which size would suit me better.
Thanks in advnace,
Kam
Old Mar 21, 2006 | 09:32 PM
steven88's Avatar
Need A Light?
245/40/19
asjkfdhkfsahydkfdj
Old Mar 22, 2006 | 10:34 AM
kamski's Avatar
.org extraordinaire
Originally Posted by steven88
245/40/19
asjkfdhkfsahydkfdj
So less contact patch/smaller diamater?
Kam
Old Mar 22, 2006 | 04:12 PM
limsandy's Avatar
Depends on what size is your 19" wheels.
Old Mar 22, 2006 | 07:40 PM
03MajesticMax's Avatar
Shift_MajesticFemale
245/40/19
asjkfdhkfsahydkfdj
Also good for 19X8?? 40 offset?
Old Apr 2, 2006 | 10:14 PM
kamski's Avatar
.org extraordinaire
My RIMS are the 19" NISMO gunmetals with the 8.5 width.
Thanks,
Kam
[maxi-overdose]
May 16, 2001 06:09 PM
rnatale
May 9, 2001 09:01 AM
humaras
Dec 22, 2000 06:15 AM
