will i need spacers with these wheels??
Old Apr 2, 2006 | 08:37 PM
SE Maxima's Avatar
ok, flame me for this question now, but i'm confused by offset and have read tons of stuff on the internet about it.
i have a '95 SE with sawblades and want to upgrade to the 2001 5-spoke rims with 215/55R16 like these:
what else will i need?? i know the lug pattern is the same, and i've calculated the outside diameter and they are very close. what about spacers? that's where i am confused. furthermore, i've priced spacers on the internet and they're expensive as cr@p! they'd add like $150-200 to the total cost.
any help would be greatly appreciated.
Old Apr 3, 2006 | 12:57 PM
MetaOrbit's Avatar
Got Projectors?
Why would you need spacers?
They should fit just fine.
Old Apr 3, 2006 | 01:05 PM
SE Maxima's Avatar
Thanks for the help. Much appreciated.
Sweet looking Infiniti. Nice to see Knoxville folks supporting the ORG and each other.
Old Apr 3, 2006 | 04:07 PM
Ammi's Avatar
350 Detroit Muscle
you dont need spacers unless you want your wheels to be pushed out a bit more
Old Apr 3, 2006 | 05:15 PM
SE Maxima's Avatar
I guess you can see why I'm confused then. I thought unless the wheels were the same width and had the same offset you had to get spacers so it wouldn't change the suspension geometry.
Old Apr 3, 2006 | 05:28 PM
MetaOrbit's Avatar
Got Projectors?
Spacers are generally used for looks (push the wheels out wider) or for clearance (make sure tires don't rub on inner fenders, wheel spokes don't hit brake calipers, etc.).
For your car, and the wheels you chose, you won't have to worry about any of that. (Unless you just want the spacers for looks...that's your prerogative)
Old Apr 3, 2006 | 06:53 PM
SE Maxima's Avatar
AWESOME. Thanks again.
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
