Acura TL rims fitment... HELP ME OUT ASAP
Old Apr 9, 2006 | 12:15 PM
drive4fun's Avatar
Will 2004-6 Acura TL 17" rims fit a 2006 Nissan without a problem. I know they are both 5x114.3. Tires are P235/45/R17. The offset is 45 and I do not know if bore center hub will fit. Can someone please help me out and tell me if it is a direct replacement.
TL Spec's Stock
PCD is 5-114.3 and hub bore is 64.1.
235/45-17 93W BRIDGESTONE 17X8.0 ALLOY +45mm offset 5-114.3 64.1hub bore 12X1.5 NUT 19MM HEAD
Our stock specs are basically the same we just have one difference.
64.1 hub is standard for the Acura TL.
We have...
66.1 hub Will this cause any sort of fitment/vibration problems?
Will they work?
By the way I have an 06 altima but the maxima's specs are identical I believe...
Old Apr 9, 2006 | 08:55 PM
MetaOrbit's Avatar
Got Projectors?
If the hub bore is smaller than ours then the hub won't fit through the wheel.
I'd say it won't fit (unless you had a machinist enlarge the hub bore).
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Pixel
Sep 15, 2015 05:53 AM
0m3nc0w
Sep 11, 2015 05:21 PM
