COBRA 18s Question...
Old Apr 21, 2006 | 01:09 PM
FriscoMaxima's Avatar
I was just wondering if:
All four rims are 18" x 9", +26mm offset
with 255/40/18 tires
will fit on a 5th gen maxima with nno rubbing? thanks.
Old Apr 21, 2006 | 04:18 PM
Jeff92se's Avatar
I'm needing a caw
It will be close but you have everything working against you (as we spoke in pms) +26mm + 9"wide wheel and the wide 255s all work to move the wheel/tire out. Not good.
It think it will definately rub in the rears.
Old Apr 22, 2006 | 12:01 AM
i tried to measure how it would work on my car, it seems perfectly fitting in the front and the back would need 10mm spacers... that's what i figured out. thanks.
BkGreen97
Apr 2, 2016 05:47 AM
MidnightMaxima_22
Aug 18, 2015 09:36 PM
bluefish
20
Jan 18, 2001 12:24 PM
Naughty
Dec 20, 2000 10:12 AM
Naughty
Dec 5, 2000 12:04 PM
