Axis Hiro wheel/Tire question
Old May 21, 2006 | 04:07 PM
soontobe's Avatar
I know this is debatable, but I want to get some opinions before I spend my hard earned cash. I have a 1995 stock GLE. First on the mod list is a suspension followed by rims and tires. I am leaning towards H&R springs paired with Tokico Illuminas. Comments on this pairing? Pros Cons?
As for wheels, I am DEFINATELY going with Axis Hiro's 18x18.5, offset 45mm wrapped with Toyo Proxies 4. Now for the tire question. I'm wanting go go with 245/40/18. On Tirerack, it is recommended to get tires that are 235/40/18. With this wheel size, offset and tire size will they stick out too far? Any rubbing issues that any of you forsee?
Finally, Does anyone have pics of this setup on a 4th generation they can post? I've seen the 5th generation on Axis Hiros, but I can't locate pics on a 4th.
My car is the silver metallic with a purple pearl with black leather. (I think it's fairly rare, I haven't seen many). I plan on posting pics along the way so everyone can check it out. I appreciate any comments..........
Old May 21, 2006 | 06:50 PM
Ammi's Avatar
350 Detroit Muscle
great suspension setup.
You can run 235s but I would run either 245/40/18s or even 255/40/18s.
45mm offset is too high. Try around mid 30s for offset.
Old May 22, 2006 | 06:07 PM
soontobe's Avatar
I never thought the offset was too high. I believe the Axis Hiro 18x8.5 only comes in 45mm offset, please correct me if I'm wrong. You don't think 255/40 would have any rubbing issues? Wouldn't this width stick out a little far given the offset? Thanks for the comments, anyone else?
Old May 22, 2006 | 09:51 PM
NmexMAX's Avatar
dot dot dot ...
You have your offset theory opposite it seems. Stick with 245/40-18.
Stock 17's are 45mm offset.
Old May 23, 2006 | 06:48 PM
Romster's Avatar
First I want to say Hi everybody, I got my '03 Maxima SE about a month ago and been reading these forums ever since. I'm still a noob though so bear with me
I also like Axis Hiro wheels (18x8.5 in particular), but TireRack doesn't have them and I couldn't find the correct offset.
As far as the tire size goes, I still dont get it. Tire rack shows 235/45/18 for wheels 18/7.5, 18/8.0, 18/8.5. Wouldn't you need a wider tire for a wider wheel? And would different wheel width make any difference for a maxima?
<- I laff'd
Old May 23, 2006 | 09:22 PM
NmexMAX's Avatar
dot dot dot ...
245/40-18 245/40-18 245/40-18 245/40-18 245/40-18 245/40-18 245/40-18 245/40-18... One more time anyone..?
IMO..
Old May 24, 2006 | 09:20 PM
limsandy's Avatar
245/40/18.... perfect offset for the fronts, maybe 5mm spacers in the back.
Old May 26, 2006 | 12:21 PM
soontobe's Avatar
Thanks for the input everyone.
Old May 29, 2006 | 04:46 AM
Nathan's Avatar
Nice choice of wheels. Tirerack.com doesn't carry Axis wheels, but lots of other shops sell them. There's even a 3rd gen member on the .org that sells Axis wheels for dirt cheap. I forgot his name, but I'd go to him.
Old Jun 3, 2006 | 03:39 PM
soontobe's Avatar
Nathan-
Were you able to remember the Org Member that sells Axis wheels?
Old Jun 3, 2006 | 05:34 PM
Nathan's Avatar
No not off hand but he drives a 3rd gen. You might be able to find posts by him in the FS section or the group deal section where he sells them.
Old Jun 3, 2006 | 06:44 PM
CanadianMoFo's Avatar
BigH sells Axis on the .org
Old Jun 3, 2006 | 08:44 PM
soontobe's Avatar
Thanks..........
Old Jun 4, 2006 | 05:36 PM
MAXRB8's Avatar
Big H is out of Calgary, Canada, the Axis guy you are looking for is Maxed up he drives a 3rd gen and he is on ebay with best prices on AXIS:
http://search.ebay.com/_W0QQfgtpZ1QQ...3aMEFSQ3aMESOI
Here's his wheel sale thread from the ORG:
http://forums.maxima.org/showthread.php?t=467539
Regarding tire size I have 245/40/18's on my 5th gen but I had the same tires and wheels on my 4th gen on an 8.5" rim with 42mm offset, no rubbing issues, but 255's will rub at full lock. Check out my domain for pics.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
