4th Gen only: 18x8.5 w/ 45 offset
4th Gen only: 18x8.5 w/ 45 offset NISMO Wheels
with 235 40 18 tires and an eibach drop (1.5), would this set fit? If I need spacers, 3 to 5 mm should be ok, but do I need them to be hub centric?
If you want to go with 18*8.5 +45 and 235/40 all around you're going to rub your spash guard if you only have 5mm spacers. And I would personally use hub centric spacers, but they don't HAVE to be.
First of all, I don't think you'd need spacers. They'd make your wheels sit flush with the fender, so as to make them look nicer, but you shouldn't have a fitment problem without them. With that said, if you are going to use spacers, you have to get hubcentric ones. H&R spacers are the best. Also, I'd get 245/40/18 instead of 235/40/18, but that's just me.
MAXSE5SPD
Sep 17, 2022 04:00 AM
steveyphat
Sep 15, 2015 03:43 PM
Violator
Sep 9, 2015 10:14 AM
