245-40/18
Old Jun 27, 2006 | 12:33 PM
Gismo-T's Avatar
B!tch We Got a Problem
245-40/18
Will 245-40/18 fit on a '98 MAX without rubbing, or should I just get 235's?
Also, It will be on a 18x8 rim.
Thanks,
Geo T.
Old Jun 27, 2006 | 12:53 PM
NmexMAX's Avatar
dot dot dot ...
It will fit..
What's the offset of the wheel?
Old Jun 27, 2006 | 01:24 PM
Larrio Motors's Avatar
Boss Chen Industries
The offset is very important in determining if the rim/tire combo will rub. Overall you should be fine if the offset isn't too excessive
Old Jun 27, 2006 | 02:24 PM
Gismo-T's Avatar
They're Enkei RPM-2 Bortex
18x8
35 offset
I'm also lowered on Progress springs!
Old Jun 27, 2006 | 02:30 PM
NmexMAX's Avatar
dot dot dot ...
With that said... there should be no problems.
Old Jul 2, 2006 | 11:15 AM
2thamax23's Avatar
I have the same ? for my rims, I have kazera rims 245-40 18 inch and my 97 max is lowered Im concerned with my handling..
Old Jul 4, 2006 | 09:35 AM
gsxr-rider137's Avatar
i want to put 18's on my 97 se as well....its stock height. the245's won't rub?
Old Jul 4, 2006 | 12:05 PM
Gismo-T's Avatar
Check 1010tires.com-wheel calculator
Old Jul 6, 2006 | 06:47 PM
redwagon29's Avatar
should fit
well this is my first post on the forum. been searchin around a lot but yet to have a need to post anything... but i just put a set of toyo proxies fx4 on my max... 245/40-18 and there is no rubbing so you guys sholdn't have a prob
Old Jul 6, 2006 | 07:10 PM
RA030726's Avatar
I'm nutty for Nissans
I have 18x8 42mm offset with 235/40's with no rubbing and room to spare. As long as the wheels offset sticks out more you should be fine.
99Maxima5sp
Tires and Wheels
Sep 23, 2004 08:16 AM
99Maxima5sp
54
Jul 12, 2004 09:20 PM
