Speedometer w/ Bigger Rim Question *Searched*
Old Jul 30, 2006 | 11:40 PM
SilverGLE's Avatar
I'm watching you, boy...
I'm about to get my G35 18's in the mail and had a few questions about it... First off, I know changing the tire size/diameter will offset the speedometer, but is this change determined by the size of the front wheels (in FWD)? My 18's will have the stock tire sizes, 225/45/18 front and 245/45/18 rear. Another question... Will I need new lugnuts (boy, that sounds like a dumb question)? Thanks!
Old Jul 31, 2006 | 12:51 PM
limsandy's Avatar
It all depends on the tire size. Check out miata.net's tire size calculator and punch in your before and after tire size and see how much difference it makes.
Old Jul 31, 2006 | 11:06 PM
SilverGLE's Avatar
I understand that, I'm just wondering if the difference in the speed is determined by the size of the driving tires (in my case, front for FWD).
Old Aug 1, 2006 | 05:36 AM
NmexMAX's Avatar
dot dot dot ...
Yes, your drive wheel tire size will affect your speedometer.
Old Aug 1, 2006 | 05:39 PM
SilverGLE's Avatar
^ Thanks! That's what I thought.
Old Aug 1, 2006 | 06:39 PM
MaximaSE96's Avatar
Maxima Owner
waht size tire do u plan on running
Old Aug 1, 2006 | 07:46 PM
Peter66's Avatar
the 225/45/18 will have a 26" diameter, not sure what your stock tire size is. Use this http://www.eunos.com/tirecalc/
Old Aug 1, 2006 | 10:35 PM
SilverGLE's Avatar
I'll be running the G35 stock tire size, 225/45/18 in the front and 245/45/18 in the rear, as I said in my first post. According to the Miata Tire Size calculator, my speedometer will be off by 2.6% (too slow). My stock tire sie is 215/55/16. I already knew all this, but am still wondering if my regular lugs will fit OK, though (I'll find out in a few days when I mount them, regardless).
Old Aug 2, 2006 | 11:07 AM
AceofSpds's Avatar
wat
Do you have pic's of the wheels? if you have a good pic i could probably determine what kind of lug.
Old Aug 6, 2006 | 10:56 AM
SilverGLE's Avatar
Nevermind about the lugs... I got my question answered. FInally just mounted them and the ones I have will work fine, but I'll probably get some longer lugs off ebay.
MR2 T'd
Jul 9, 2021 05:06 AM
mikeymouse1995
Sep 18, 2015 06:42 AM
Djsmaxima
Sep 14, 2015 11:58 PM
0m3nc0w
Sep 11, 2015 05:21 PM
adamgalazka
Sep 8, 2015 01:27 PM
