Any lowered 4th Gen running 225/55R16?
Originally Posted by KK1
can anyone tell me if I use 225/55/16 tires for 4 th gen Max auto, does it make my car slower on top speed or does it become slower in various speed?
Originally Posted by limsandy
I assume you're referring to acceleration? If yes, 16" would actually make you faster(if you were using 17" or 18" previously). Then again, it depends on the weight of your tire + wheel.
Depends on why your car stopped accelerating. If you were at red line in high gear, you are "gear limited" Changing the diameter of the wheel package will affect top speed. If you were not at red line you are "power limited" changing the tire size will not change top speed.
I was using before 15' 205/65/15 now I have 225/50/16, top speed is slow only 134,5 mph. I would expect 145 at least. does 225/55/16 increase top speed? or does it rob the power in middle revs?
No, it doesn't.... in fact it might make your acceleration slower, very slightly..... I hope you didn't run 134 mph on the highway?
Originally Posted by bogeyman007
it won't rob u of anything but it will take away a little acceleratoin and raise your top speed, that's only if you have the power though to get up that high.
When it stopped accelerating in top speed was it from lack of power or
from auto gearbox?
How much the top speed raises?
Finkle
Sep 27, 2015 09:53 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
