need help with wheels offset and size...
Old Sep 15, 2006 | 06:56 PM
OC guy's Avatar
2002 maxima se
I am planning to purchase a set of wheels from ebay..but i am not too sure if those rims will fit on my 2k1 se. i have 17" stock 6 spoke. but i dont know the offset and bolt pattern etc.......rims that i wanna buy some of those are with universal lugs.
FOR AN EXAMPLE HERE IS WHAT I FOUND ON EBAY WHEELS SPEC:
SIZE: 17 X 7
40 OFF SET 10 HOLES UNIVERSAL 5 LUG
5X100/114.3
what you guys think... the above offset size will fit my 2k1? and whats the diffrenence between the numbers of offsets?
please help me find the right rims for my car///
thanks!
Old Sep 15, 2006 | 07:17 PM
z32drifter's Avatar
I think a 7" wheel is kind of a waste. I would go 8+ if replacing wheels. I have a 4th gen so fitment may be diff. I would think 7 +40 will sit a little to far under the car.
Old Sep 15, 2006 | 07:38 PM
irish44j's Avatar
retired moderator
your stock wheels are 17x7 with a 42 or 45 offset. Lug pattern is 5x114.3 The ebay ones will fit fine, but here's some food for thought:
1. If you're upgrading wheels, go with a wider rim (7.5-8"). Otherwise, it's not much of an upgrade.
2. Consider an offset closer to 30-35, which will bring the wheels out more flush and give it better stance, appearance, and handling. Look at my sig pic...30mm offset.
3. I've never been a fan of 10-lug universal lug patterns for two reasons: 1) it looks stupid and 2) IMO it makes the hub portion of the wheel weaker. Find a good wheel that is a standard 5x114.3 without the universal.
Old Sep 15, 2006 | 07:49 PM
OC guy's Avatar
2002 maxima se
you are the man....thanks alot, and did u mean that i should go for 17x8 with between 30-35mm offset?
i also did not pretty much like the universal...BTW do u know any better and decent store on ebay to buy wheels?
Old Sep 15, 2006 | 08:22 PM
irish44j's Avatar
retired moderator
With a 17x8, go with a 35-38 offset or so to avoid any possibly rubbing
With a 17x7.5 go with a 30-35 offset
Make sure to use the correct size tires. 235/45/17 is appropriate with these rims. 225/50/17 will fit too, as will 245/45/17.
As to where to buy....I don't do ebay stores...Go with a reputable seller selling a reputable ("name") brand. I don't know what style you're going for, but check out tirerack and edgeracing.com for some good prices on good quality wheels.......it's worth paying a little bit more for a quality wheel that will not bend easily like alot of fakes will...
limsandy's Avatar
<<< never a fan of ebay wheels
Old Sep 15, 2006 | 08:46 PM
OC guy's Avatar
2002 maxima se
Great site with some inexpensive wheels sets.
thanks alot irish.
which color and style you think will look better on my pearl white se...? as i wouldnt go for universals or heavy rims...the followings are between 17lbs to 18lbs each. there are 23lbs ones but i guess those would be way too heavy.
1.
2.
3.
4.
5.
Old Sep 15, 2006 | 08:47 PM
OC guy's Avatar
2002 maxima se
6.
Old Sep 16, 2006 | 07:28 PM
irish44j's Avatar
retired moderator
I'm a big fan of either of the Black Racing wheels - they're similar in appearance to my 5zigen track wheels, but with an extra spoke that makes them look ALOT better.
That Falken Explicit (3rd one) is ugly as hell IMO.
The Fliks are decent looking but I'm no fan of polished lips..
On a white maxima, I really like the bronze Black Racing ones (first ones)....I think those would look really good - plus they are pretty lightweight, which is always important!
Old Sep 16, 2006 | 07:30 PM
irish44j's Avatar
retired moderator
holy crap...those Black Racing wheels are a great deal.....perfect offset too in the 17x7.5 35mm offset...
the 17x8 31mm offset would probably fit too and they are an AWESOME price...damn, if they were a bit lighter I'd get them to replace the 5zigens...
Make sure you act fast though, edgeracing sales don't usually last very long!
Old Sep 17, 2006 | 10:36 AM
OC guy's Avatar
2002 maxima se
thanks irish
WHAT DO U THINK ABOUT (EXEL) BRAND...HOW WOULD YOU RATE THIER WHEELS?
is it better to go for a brand that distributed by japan?
Old Sep 17, 2006 | 12:58 PM
limsandy's Avatar
Come on... this is just a few thread below yours.....
http://forums.maxima.org/showthread.php?t=490791
Old Sep 17, 2006 | 01:12 PM
irish44j's Avatar
retired moderator
thanks irish
NO...exel are not japanese wheels, and they are crap quality. Stay away. Far away.
Old Sep 17, 2006 | 02:37 PM
OC guy's Avatar
2002 maxima se
what about koniko or something....?
Old Sep 17, 2006 | 03:11 PM
irish44j's Avatar
retired moderator
where are you getting these random brands from? I've never ever heard of koniko.
Stick with known names...SSR, Rays, Volk, Enkei, Kosei, 5Zigen, Falken, etc etc.
Black Racing is not a well-known name, but I know they're good because I've seen several top autocrossers using them...
Old Sep 17, 2006 | 04:22 PM
OC guy's Avatar
2002 maxima se
thanks alot...
i bought a set of chrome wheels from pepboys sevaral months ago there was a sale for $125 each. i used them for a week then returned them due to vibration issue, i had my car checked and one of the wheel was defective/bent which was causing vibration. thats the reason i was looking for a better and decent wheels store online, i believe its easy to return the item if you buy it from local auto stores rather buying something online and if it goes defective then you have to go thru many hassals just to get refund or exhange on your item...so thats why i am being extra considered to buy something online with famous brand and a company that stands behind thier product. i was planning to purchase a set from www.wheelmax.com but since i heard the case about the broken structure that changed my mind on EXEL brand. one thing is also true that you have to pay more to get something better and ever lasting. oh well i like the website that you reffered and will look forward to purchase a set from them once i finished with some of my inquiries on thier products. anyway thanks alot for putting me on right way...i have learned alot by posting my questions here and u have been the great help so far. i hope u wouldnt mind helping me out in future with more questions.
BY THE WAY....I MISUNDERSTOOD THE BRAND AND SAID (KONIKA) ACTUALLY ITS (KONIG) AND ALSO I CHECKED OUT (HOT WHEELS) (VOXX) (RAGE) (MB WHEELS) AND (X6) WHAT DO U SAY ABOUT THESE BRANDS HAVE U EVER HEARD OF THEM? THE FOLLOWING PHOTO ARE "LIQIUDMETAL" AND "VOXX" BRAND ...PLEASE SEE AND COMMENT.
Old Sep 17, 2006 | 06:33 PM
irish44j's Avatar
retired moderator
Never heard of Liquidmetal...Voxx I've heard of but know nothing about.. Konig generally makes pretty good wheels.
As to wheelmax....they just seem like an online rice shop, with alot of cheap-o brands, to me..
I mean, on their front page this is the "featured" wheel:
Quality places have "featured wheels" that are well-known brands like SSR, Volk, or the like....not some ricer blingy wheels.
Seriously, stick with companies that are known for their great customer service and high-quality products, like edgeracing and tirerack. That's my suggestion.
Or, if you want to know what wheels are good quality, go look at what the guys in the autocross section are running - people who race tend to buy good quality, strong wheels...
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
