15mm Spacers on rear rubbing with 19" Axis Mods
Old Sep 25, 2006 | 03:24 PM
00MaxSE's Avatar
Pointy Elbows
I put some 15mm H&R spacers on the rear of max. I have 19x8 Axis Se7en Mods. If I take a turn too sharp/fast, the tire will rub on the fender.
I don't want to roll my fenders, so does anyone know if 10mm spacers would be ok? I'm not sure what the offset of my wheels is.
Old Sep 25, 2006 | 04:07 PM
MetaOrbit's Avatar
Got Projectors?
10mm spacers (H&R or hubcentric for that matter) don't exist...to my knowledge.
You'll have to go from 5-15.
Is it rubbing only on one side? Usually it's the right side which will rub, and a while back Larrio posted a procedure to re-center the rear beam so that should no longer be a problem.
If that's not the issue, then rolling the fenders is probably the solution.
I have my fenders rolled AND I took an angle grinder to remove some of the "tab" inside the wheel well that caused some of the rubbing.
Old Sep 25, 2006 | 05:21 PM
00MaxSE's Avatar
Pointy Elbows
Yeah, I was searching some sites and didn't see any 10mm spacers by H&R. I see that Eibach makes them though. Are those just as good?
And yes, it's the right side that rubs and I saw that tab you mentioned.
I'll have to find Larrio's procedure. I hope it's not too involved. I'd rather not grind down the tab because it would rust eventually.
EDIT: how bout this? http://www.sportcompactonly.com/prod...c=142&l=2#apps
Old Sep 25, 2006 | 05:55 PM
MetaOrbit's Avatar
Got Projectors?
Have the beam re-centering bookmarked, actually:
http://forums.maxima.org/showpost.ph...2&postcount=18
As for the spacers, the link shows a million spacers, and the ones listed that were 10mm I saw were for the wrong bolt pattern.
I'm sure you could use a 10mm spacer, but it wouldn't be hubcentric. Not the way our hubs are designed.
As for the grinding, I cut out the metal/plastic in the way and then re-coated it with 3M rubberized undercoating for rust prevention.
Old Sep 25, 2006 | 07:11 PM
Nathan's Avatar
Awesome, thanks for posting this link. I had the rubbing on the right side only too.
Old Sep 26, 2006 | 04:30 AM
MaximaSE96's Avatar
Maxima Owner
or u can lose the spacers all together cause obviously if ur rubbing with 15mm then u prolly dont need them at all...
Old Sep 26, 2006 | 08:13 AM
00MaxSE's Avatar
Pointy Elbows
Thanks for posting that, MetaOrbit. I'm a little confused about it though. Is there a write up with pics?
Will doing this stop my rubbing for sure?
Old Sep 26, 2006 | 08:37 AM
NmexMAX's Avatar
dot dot dot ...
Only one way to find out.
Old Sep 26, 2006 | 08:49 AM
00MaxSE's Avatar
Pointy Elbows
Alright, I'll see what I can do this weekend.
Old Sep 26, 2006 | 09:32 AM
MetaOrbit's Avatar
Got Projectors?
The original thread has some pics:
http://forums.maxima.org/showthread....52#post4862652
(if you were referring to the beam re-centering)
As for the grinding...just look up inside the wheel well and see what it's rubbing against (if that's your problem). Grind and re-coat.
Old Sep 26, 2006 | 12:34 PM
00MaxSE's Avatar
Pointy Elbows
Yup, I searched earlier today and found that thread. Thanks man.
I was just thinking...When I installed the spacers, I had less than a 1/2 tank full of gas and no rubbing. I only started to rub after I filled up on gas. Aha!
A temporary solution.
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
A32goldylocks
Sep 2, 2015 06:39 AM
